hf hub/spindle for b16 other than si.
i'm pretty sure...any 88-91 (non crx hf or non 4spd civic) knuckles will work...it doesn't have to be an si model...not sure about tegs or other gen civics/crxs
i ran into an si at a junkyard where i got my front knuckles (i also own an hf)
[Modified by jaje, 10:28 PM 5/23/2002]
jaje: yeah i know dx and si hub/spindles will fit. just wondering of any other civic or teg ones will fit..
main reason because i dont think there are any dx or si's in any yards around here.
hardware17: i'll let you know if i end up needing them. thanks.
with fitment issues i always call the honda dealer...i found out the hf and si of each year use the same distributor...but the 90-91 are different than the 88-89...i'm gonna try to use my 88 hf's distributor on my 90 si engine (i only found that out when i called my local dealer)...maybe try calling yours about the knuckles and let us know
did a little research. from hasport they show you what all axles you need for what int. shaft you have. and they never say anything about the hub/spindle or anything being different on the 89-91 civic/crx sir, 90-93 teg, and 94+ teg gsr (also in JDM 92 up SiRs, 99-00 Si and Type R) . so some common sence in here. that all the axles will fit fine in any of those hub/spindle setups. but thanks for the info guys.
-matt
-matt
trust me, theyre different. im working on mine right now, theyre helluva different, or im just screwed. If you need them, get back with me ASAP. I leave for BMT on June 3rd
only reason i was looking at getting teg or other gen civic ones is because i didn't think i was gona beable to find an si. but we ran across one yesterday. so i just got them off the si.
TheJunBuilt
Sep 24, 2004 10:03 AM
gsr355
Mar 20, 2002 04:01 PM
