LS swap into my 90 Si CRX
Use the stock Si harness (NEVER try and swap to another harness ALWAYS use the stock harness)
And most likely yo won't have to modify the harness at all, did a B18b swap in my 91CRX Si, the only wire i had to extend was for the rad fan sensor and that was only because OBD0 motors have it on the back of the block and OBD1 have it on the thermo housing...I think there will be a sensor that you don't have to plug in...
