clutch question
i bought a clutch for my gsr crx which had a b17 cable trans...but then i sold the car whiout installing the clutch.. is it a problem if i were to put it into my 99 ek hatch w/ gsr hydro motor???is the difference between cable and hydro just the way the pedal works with the trans? can i still use my clutch/flywheel in a hydro trans?i am just wonderin cus i thought the pressure plate/disc/flywheel were universal bewteen 90-01 integra but when i ordered it, it was in seperated between 90-91,92-93, and 94-01... and i ordered the 92-93 because i had a 93 b17a trans... thanks in advance
all 90-01 b-series use the same pressure plate, but the disc varies from 90-91 to 92-01. The spline size is the difference. So if you have a disk from 90 or 91 you will need a new disk for your hydro trans.
