problem with d15b2 motor
Old Mar 18, 2007 | 06:46 PM
eguser's Avatar
Default problem with d15b2 motor
i recently purchased a 91 dx hatchback that is bone stock. when i bought it the sparkplug in the 2nd cylinder was crossthreaded and i had to remove the head and i ended up just replacing the head because a friend had one lying around. but anyways it stumbles at idle real bad so that i have to keep it running pretty hard to keep the engine running. it also smokes like a bitch all the time. i think the rings might be bad? the headgasket is brand new and it sealed wonderfully i think ( no water in the oil so i suppose it did?) is there anything i can do to get rid of the smoking i just want the car to put miles on it right now my daily driver is a 94 eg hatch with a b16a and i don't want to put 120+ miles per day on it you know???
eventually, probably the end of the summer i will have a zc motor in the ef but i want to drive it a bit until then
thanks yall
Old Mar 18, 2007 | 07:17 PM
satinsol's Avatar
Run seafoam through it and see if that works I doubt it will but it might clean it out and stop some of that smoke
Old Mar 18, 2007 | 07:40 PM
nappyroots827's Avatar
Default Re: (satinsol)
the head you got probably has bad valve stem seals, probably leaking **** tons of oil into the ports causing the rough idle and smoke
Old Mar 19, 2007 | 05:47 AM
eguser's Avatar
Default Re: (nappyroots827)
i tried seafoam it didn't help and then i put in some "stop smoke" and some "engine restore" so maybe that will recondition the seals if they aren't missing chunks. thanks
yewdontknowme
Sep 21, 2014 03:09 PM
baggedmazda
Mar 6, 2012 02:58 PM
turbo_ls_69
Aug 15, 2010 06:56 PM
Twisted Image
Apr 16, 2007 04:06 PM
Twisted Image
Apr 15, 2007 08:03 PM
