Misfire/skip under load and at high rpms...
Old Mar 18, 2007 | 06:33 PM
VTecLude1994's Avatar
Default Misfire/skip under load and at high rpms...
I've searched and from what I can find all these people are throwing codes. I have no CEL and under load and at high rpms I'm getting a misfire. When the car has been driven 30 minutes or more it's fine...
Plugs, wires, dizzy cap, fuel filter, and rotor button are only about 5k miles old.
Modified by VTecLude1994 at 11:08 AM 3/19/2007
Old Mar 18, 2007 | 08:52 PM
TruNinja619's Avatar
Default Re: Misfire/skip under load and at high rpms... (VTecLude1994)
what kind of motor are you running?
H22A1?
I would start out w/ a checking/adjusting your valves..
Old Mar 19, 2007 | 07:08 AM
Default Re: Misfire/skip under load and at high rpms... (TruNinja619)
H22A1 correct. Valves were adjusted when the plugs, wires, dizzy cap, fuel filter, and rotor button were changed.
Mods are Megan Header /w 2.5" collector mod, Megan Test Pipe, Custom 2.5" Mandrel Catback, Apexi V-AFC, and AEM CAI.
The distibutor is kinda corroded from where I got the car from up north could this be an issue?
Old Mar 19, 2007 | 07:37 AM
gavzter's Avatar
how is the distributor corroded?
assume you've checked the timing, fuel pressure etc?
does the misfire only happen on WOT?
Gavz
Old Mar 19, 2007 | 07:41 AM
ITS_Dunn's Avatar
Had the same problem here. Honda adjusted the valves at 60k and turned out that they tightened the valves too tight. Had to fight with them for a few weeks and they never did fix it. I had it done myself. They told me it was all the basic **** and because the car had a CAI and Exhaust it was causing the car to misfire.
F ucking idiots.
Moral of story is again, check valves.
Old Mar 19, 2007 | 01:31 PM
copeman's Avatar
Default Re: (Dunn@ITS)
I had a similar problem but different. Honda had no idea how to fix it, they replaced my ignitor and my dizzy even though the dizzy was new anyways. Didn't fix anything, so they told me I needed a new ecu and they wanted $800. hahaha I was pretty sure it had nothing to do with the ecu so I told them to expletive themselves. Turns out it was a bad ignitor connection, replaced the little thing and everythings perfect. Too bad my lude drove like **** for 3 months and Honda made total asses out of themselves. The lady who gave me the most trouble got fired(unrelated but thank god shes gone) so I went back and the service manager refunded me $250 for the ignitor they should have replaced for free. hahaha
Old Mar 20, 2007 | 06:00 PM
Default Re: (copeman)
Well my valve adjustment was a little off so I redone that today and I still have the same problem.
And yes Gavzter I've checked the timing and fuel pressure both are right. And yes it only happens at WOT.
Old Mar 20, 2007 | 08:54 PM
Default Re: (VTecLude1994)
Bump'n it!
Old Mar 21, 2007 | 05:31 PM
Anything?
Old Mar 21, 2007 | 06:09 PM
TheWalrus's Avatar
it may have something to do with the v-afc...who installed it? id check those connections
Old Mar 21, 2007 | 06:16 PM
kulrevon's Avatar
maybe try checking the connections on the igniter.
Old Mar 21, 2007 | 07:39 PM
Default Re: (TheWalrus)
The V-AFC wiring is correct I've checked it.
I shall check the connections on the ignitor tomorrow.
Old Apr 4, 2007 | 06:08 AM
Ordered an entire new distributor...we shall see.
Old Apr 4, 2007 | 07:02 AM
98vtec's Avatar
moderator emeritus
were your plugs pregapped?
Old Apr 4, 2007 | 07:55 AM
mgags7's Avatar
damn you must have dropped a mint on the dizzy
what kind of plug wires are on there?
Old Apr 4, 2007 | 07:26 PM
Default Re: (mgags7)
NGK plugs were pre-gapped and I checked them and they were right(I used .044). And I'm running NGK wires.
A few of my friends have actually used Distributor King on eBay and got great products. I figured I'd try it...149.95 shipped.
Modified by VTecLude1994 at 11:38 PM 4/4/2007
Old Apr 4, 2007 | 07:45 PM
zirac50's Avatar
just had same problem w/ u , but it's all good now. I found out that vavles were too tight and the egr valves had lot of carbon in it. I finally it's done. woowooo
Old Apr 9, 2007 | 05:45 PM
Default Re: (zirac50)
Well the new dizzy fixed it.
GregoryBRCRV
Honda CR-V & Element
Feb 17, 2016 08:58 AM
Connected sedan
Feb 12, 2013 01:25 AM
dgreenwud
Nov 16, 2003 04:29 PM
lbjoe
May 22, 2003 04:41 PM
Hybrid Boy
Sep 1, 2002 03:16 PM
