Mounting a Kirkey racing seat???
im having trouble finding the rules or way to mount my seat that will pass tech inspection? is there a rule to fallow? a size of metal or size bracket? if somone could help me out and or show some pictures it would be awesome.. thanks
it shows in the rulebook about mounting it.
look in general rules/regulations. i belive somewhere around section 10-
although ours is mounted on tabs, which are welded to plates, which are welded to the floor. the seat is bolted to the tabs with 1/2inch bolts.
look in general rules/regulations. i belive somewhere around section 10-although ours is mounted on tabs, which are welded to plates, which are welded to the floor. the seat is bolted to the tabs with 1/2inch bolts.
Cheesefries333
Nov 6, 2006 04:54 PM
