Info on 1st Gen CRX
hey i recently found a 85 CRX and wanted to know what all mods are out there for it and some info ... and how rare and 15" Enkei mesh wheels are
Thanks, Matt
Thanks, Matt
you can pretty much do any thing you want to a first gen that you can do to a 2nd gen you just have to look really hard for parts... but they are out there.
http://www.redpepperracing.com is the best site in the world for them.
but specify what you are looking for and I would be glad to list you some sources
old pics:
Modified by MemoryCRX at 7:42 PM 3/18/2007
old pics:
most of the products are discontuined
for suspension there is a tein kit that is a special buy type of deal here http://www.redpepperracing.com...27982
you can send your stock front shocks to koni and they will rebuild them shorten them and make them double adjustable, for rears you have to buy used,
ground controll makes nice coilovers for the rear and you can get any spring rate you like,
torsion bars can be found at upgrademotorsports
panhard bars are hard to find, but they are floting around out there rpr and opm made them
addco has a really nice rear swaybar kit, and ST has front and rear sway bars.
if its a auto ew 85 then yeah a b16 swap is not going to be easy you will need to convert to fuel injection, from an 84-87 SI crx (assumeing you dont have a SI auto) HAsport has all the fun swap stuff you need. but its a real hassle to do a FI swap into a carbed car. its do-able but I dont recomend it unless you have a SI donor car or wire harness at lest. you will need to change to a si fuel tank and lines too.
85CRXsi
Nov 9, 2003 08:37 PM
HondaPartsHero
Oct 2, 2003 08:50 PM
l3loodred
Sep 16, 2003 05:10 PM
