d15 b head
I have a head off of a d15b motor and i am puttin it on my d15b1......now will this gimme more compresssion adn does any1 know the compression on the b15b1 motor? my last question is what will the d15b head acctually do for me???
If you are refering to the jdm d15b sohc vtec head than in terms of compression ratio it will be just like putting on a d16z6 head and your bottom end is identical to a d15b2 or d15b7. that head on your engine with a metal head gasket (96-00 d16 headgasket) would put you at about 10.1:1 stock is about 9:1 go here you can calculate your d-series compression with lots of different combonations. http://www.knology.net/~jediklc/dcalc.htm
putting the jdm d15b vtec head on your engine will essentially be a mini-me, the new head flows better than your old one, and has much better cam profiles than your old head (d15b1's have a terribley weak cam), and a higher compression, all of the key factors to making more power. A stock d15b is supposed to make about 130 crank hp, doing this head swap on your engine won't get you quite to 130 crank hp but close as long as your lower end is in good shape, and you do the correct wiring and run the correct ecu etc...
well this is goin in my race car.....it is a civic std and has to stay throttle body, but with the head i am gasket matching the head and have a manifold off of a dx that is also ported, is there anything i can do to the computer or anything or is there a computer that would be good to use in this car???.....thanks alot for all ur help by the way!
Actually, I heard that if you run the P30 ECU and dizzy, that it really opens up the motor. I just bought a D15B off of Ebay and I was thinking of trying it. They say that it's supposed to make damn near 150 crank HP with this combo but you know what they say...you never know until you try. I'm sticking with the P28 (which is on the way).
P.Raickovic
Mar 13, 2016 02:53 PM
