For those 4th gen auto to manual people!
Old Mar 18, 2007 | 02:38 PM
SteveoBA8's Avatar
Default For those 4th gen auto to manual people! Tranny mount question
Ok hang with me here. My 94 was orginally F22a1/automatic, i converted it to 5spd and a jdm h22a.
My 92 is a factory 5spd car.
I have noticed the tranny mount through bolt hole is different.
My 94, Auto mount hole location
Then my 92, 5spd hole location
The actual mounts welded to the frame appear to be the excact same.
My question is has anyone re-drilled and moved the hole? I keep hearing clutch chatter( last spring break i installed exedy oem replacement clutch, resurfaced oem flywheel, rear main seal) so i know it's not that. I've read that mis-alignment of engine/tranny mounts/worn mounts can cause clutch chatter, correct?
I plan on getting a set of aftermarket mounts, so im betting that lining up the tranny mount will be a royal bitch( it was last time). Help please.
Old Mar 18, 2007 | 03:20 PM
Hawkze_2.3's Avatar
Default Re: For those 4th gen auto to manual people! Tranny mount question (SteveoBA8)
Does the engine sit level?
Old Mar 18, 2007 | 03:34 PM
SteveoBA8's Avatar
Default Re: For those 4th gen auto to manual people! Tranny mount question (Hawkze_2.3)
Nope, the vc leans down towards the tranny side. It is very noticeable from the front.
Old Mar 18, 2007 | 03:43 PM
Hawkze_2.3's Avatar
So it seems like you definately need to fix that I assume the auto mount is different from the manual mount?
I'd drill a new hole to level the engine out. Probably need a die grinder to get into that area...
Old Mar 18, 2007 | 04:23 PM
kulrevon's Avatar
I actually noticed this a while ago when I was doing research for mounts. The auto and the manual actually have different mount points. I was wondering why no one has noticed this before.
heres the proof hope it helps you on how far to move the hole. So it needs to be moved .67 inches down. and .51 in to the right
Old Mar 18, 2007 | 06:44 PM
SteveoBA8's Avatar
Default Re: For those 4th gen auto to manual people! Tranny mount question (kulrevon)
.67 inches up and .51 to the left you mean?
Thanks for those pics. Assembly line specs? Where did you find those?
Can i weld on a new mount if need be? If i drill the hole it will end up being a big slot because the bolt head is 3/4 of an inch. My 92 has 193,xxx miles, way more rust than my 94, has been wrecked mutiple times, or i would just swap everything.
I'm open to any advice, thanks guys.
Old Mar 18, 2007 | 07:21 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 &raquo;</TD></TR><TR><TD CLASS="quote">.67 inches up and .51 to the left you mean?
I'm open to any advice, thanks guys.</TD></TR></TABLE>
The Helms has those specs back in the body section for frame alignment and things like that.
Have you thought about drilling out the spot welds on the brackets and swapping the actual mount brackets to the other car? Would be some welding but you wouldn't have to cut anything...
Old Mar 18, 2007 | 07:31 PM
SteveoBA8's Avatar
I need to check majestic and see if they sell the actual mount to weld on.
I plan on pulling my engine/tranny and doing some "stuff" so i need my 92 to drive to work and what not.
Old Mar 18, 2007 | 07:43 PM
Rosko's Avatar
the nut on the backside might be difficult to relocate as well since its welded to the mount. thats interesting though.
Old Mar 18, 2007 | 07:51 PM
SteveoBA8's Avatar
Default Re: For those 4th gen auto to manual people! Tranny mount question (Rosko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote">the nut on the backside might be difficult to relocate as well since its welded to the mount. thats interesting though.</TD></TR></TABLE> yep Welp i'll start searching for a mount tommorow. Thanks guys
Old Mar 19, 2007 | 08:13 AM
SteveoBA8's Avatar
I'll take a pic of how the engine sit's after work. Mgag's? i know you converted
Old Mar 19, 2007 | 12:02 PM
my9thtry's Avatar
should this be a major concern? i mean there is countless people with auto to manual swaps out there right?
Old Mar 19, 2007 | 12:32 PM
pprowler6's Avatar
Default Re: For those 4th gen auto to manual people! Tranny mount question (my9thtry)
i converted, but didnt seem to have that problem i know the tranny mount for the auto is diff from the manual. but i did have some trouble gettin all the holes to line up.
Old Mar 19, 2007 | 12:43 PM
luder94-ChrisA's Avatar
Default Re: For those 4th gen auto to manual people! Tranny mount question (pprowler6)
my current lude is an auto to manual swap. i didn't move the tranny mounting point. i've tracked it for several years with no problems
Old Mar 19, 2007 | 01:12 PM
4G92's Avatar
very good discovery~! i have never heard of this when reading the how to articles anywhere.
Old Mar 19, 2007 | 04:04 PM
SteveoBA8's Avatar
Default Re: (4G92)
Thanks for the responses.
Old Mar 20, 2007 | 10:37 AM
my9thtry's Avatar
Default Re: (SteveoBA8)
does anyone out there think it would be a bad idea to drill th new hole in the existing auto trans mount and weld a new nut on the backside?
Old Mar 20, 2007 | 11:38 AM
syntax.'s Avatar
wow, this is news to me. I didnt realize they were different at all. My car vibrates at idle waaaay more than id like, but i always assumed it was the ES inserts causing it, not a missaligned tranny mount after the swap.
Old Mar 20, 2007 | 01:05 PM
SteveoBA8's Avatar
Default Re: (syntax.)
I think drilling a new hole would make it weak seeing that the bolt head is almost 1inch and the welded nut is about the same, and with the distance the hole needs to be moved, it would be a slotted hole. But im not the smartest person so i could be wrong .
I've never read of anyone moving the hole, I think i found the mt tranny bracket that could be welded on http://www.hondaautomotivepart...KHEAD #30
Keep this going guys
Old Mar 20, 2007 | 01:10 PM
mgags7's Avatar
Good stuff steveo
I'm about to go outside and verify this on my '96
I have ES motor mount inserts and its always a BITCH to get that mount in.....I have no clutch chatter problems though, just a little extra rattling.
On a good note the angle being off like that effectively makes our mounts stiffer, lol....
Old Mar 21, 2007 | 08:54 AM
SteveoBA8's Avatar
Default Re: (mgags7)
When i pull the engine/trans i'll take a look at my clutch and flywheel, probably going with a lightened this time.
Does #30 look like the only thing i need to order?
Old Mar 21, 2007 | 09:55 AM
kulrevon's Avatar
yeah I think thats it. Let me know how hard it is to switch them.
Old Mar 21, 2007 | 03:05 PM
SteveoBA8's Avatar
Default Re: (kulrevon)
Cool, I wont be doing this until may when i pull everything but i just wanted to plan ahead. Might as well re-paint my engine bay hmmmm. Thanks again and i will make a new thread when im done.
Old Mar 21, 2007 | 05:26 PM
kulrevon's Avatar
if you could pm that would be awsome. I was thinking about taking my mount out because I was working on a "different" swap and might need clearance.
But if the swap didnt work I wanted to put the stock mount back in.
Old Mar 21, 2007 | 08:34 PM
pprowler6's Avatar
so since i converted and the holes are diff could this be causing my dash to vibrate like crazy when in 2nd and 3rd gear?
