turn signals and hazards dont work
well i just replaced the ignition switch on my girlfriends 1994 accord lx, and now the turn signals and hazard lights dont work. ive checked all of the fuses and made sure that the plug on the back of the turn signal stalk was securely connected and it was. the headlights work and the dash illuminates when they are on like usuall, and high beams work fine and the high beam light comes on the gauge cluster when the high beams are on. absolutely nothing happens when i turn on the turn signals or when i hit the hazard lights. everything worked fine before i replaced the ignition switch, but i dont think the ignition switch has anything to do with it. anyone have any ideas?
hmm thats strange only thing i can think of is the flasher.. which should be located under the dash.. inside the fusebox.. i did an experiment when you remove the flasher.. blinker relay neither the turn signals work or hazard work.. so im assuming this is bad.. try to swap it with one thats good...
thanks for the idea, but i fixed it already. i had the hazard switch unplugged from when i was trying to clean up the cd player installation earlier that day. i unplugged it and forgot about it. im an idiot...
