dsm questtion bout the injectors
i got some dsm injectors off this turbod talon at my local junkyard
and the cap things are 2 blue and 2 black did i get the wrong ones??
because i ask iv seen ppl with all 4 blue caps or all 4 black caps
well there is actually a difference between the bluetop ones and the blacktop ones. yeah... i just searched it up so i could find out the same thing. you should not mix with those 2 different kinds of injectors. so use all 4 bluetops or use all 4 blacktops. the bluetops have a single-spray pattern while the blacktops have a dual-spray pattern. hope this helps, just my 2 cents.
My friend had a set of blue ones and said that there the better of the two
. im running them on my LS turbo setup. i have a 93 integra so i have to wire up a resistor box. (not sure if u have to do that or not )
theres a number on the injectors it says like 450mls (mls might say something else, just make sure the 450 is there) its where the injector clips plugs into. (hope that makes sense)
