can't fit usdm downpipe/header onto my h22a jdm - help!
Old Mar 18, 2007 | 10:59 AM
951dc5's Avatar
Default can't fit usdm downpipe/header onto my h22a jdm - help!
my usdm motor blown and i just swapped a h22a jdm onto my 93 prelude vtec. the only problem is the usdm downpipe is hitting against the oil pan from not letting header fit perfectly onto the head. please help. i need this fix asap. or no ride to work. thanks
ohh and the motor year is 97. is this why? because my i'm using my stock header/downpipe from 93 h22a1.
btw do i need to find a particular jdm header so it'll fit onto the h22a jdm?
Modified by Prelude951 at 12:16 PM 3/18/2007
Old Mar 18, 2007 | 02:21 PM
kulrevon's Avatar
Default Re: can't fit usdm downpipe/header onto my h22a jdm - help! (Prelude951)
use your 97 down pipe
Old Mar 18, 2007 | 02:38 PM
951dc5's Avatar
Default Re: can't fit usdm downpipe/header onto my h22a jdm - help! (kulrevon)
when i bought the jdm long block. it has the header only and not the downpipe. will the 97 usdm downpipe fit or it has to be 97 jdm? let me know. thanks
Old Mar 18, 2007 | 04:32 PM
M2B4's Avatar
either
Old Mar 18, 2007 | 07:07 PM
951dc5's Avatar
Default Re: can't fit usdm downpipe/header onto my h22a jdm - help! (M2B4)
i guess i'll have to dent the pipe down for clearance
Old Mar 19, 2007 | 08:01 AM
92blkJDMh22's Avatar
why dont you try it..... seems like a 15 min job to me.....
Old Mar 19, 2007 | 10:40 AM
ITS_Dunn's Avatar
im sure you can find a stock header for a 97 lude for free, just ask around.
Old Mar 19, 2007 | 03:48 PM
951dc5's Avatar
Default Re: (Dunn@ITS)
97 stock downpipe would fit with jdm top header? i thought all h22 engine are the same, shouldnt i have any problem installing the stock usdm downpipe? or tell me.. is it the oil pan of the jdm is bigger?
Old Mar 19, 2007 | 04:45 PM
kulrevon's Avatar
Default Re: (Prelude951)
the oil pan should not be different.
try the US upper and lower The one that was in your car before the engine swap.
I don't understand why this is so hard.
Old Mar 19, 2007 | 05:25 PM
951dc5's Avatar
Default Re: (kulrevon)
i did try the usdm upper and lower header together but the lower pipe is hitting underneath the oil pan and that is causing the header not to line up the head bolts. i think 97-01 h22 uses different header from 92-96. damn i knew i should've stick with 92-96 h22a and not 97.
btw JDM and USDM Top pieces are the same. so the downpipes are interchangeable. anyone has the downpipes jdm they wanna sell?
Modified by Prelude951 at 6:57 PM 3/19/2007
Old Mar 19, 2007 | 06:10 PM
ITS_Dunn's Avatar
am I the only one who is lost?
Old Mar 19, 2007 | 07:33 PM
1GPlusSH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunn@ITS &raquo;</TD></TR><TR><TD CLASS="quote">am I the only one who is lost?</TD></TR></TABLE>
lol, no
Old Mar 19, 2007 | 08:33 PM
M2B4's Avatar
Default Re: (1GPlusSH)
ok so heres what im understanding. u have a 4th gen and put in a h22a4(5th gen).
ur 4th gen usdm manifold and downpipe dont fit so....use a 5th gen downpipe and manifold.
Old Mar 19, 2007 | 08:48 PM
you know you dont need to bolt that bracket up to the back of the oil pan right..... most of the time it will just snap off in the long run anyway.....
if you let it hang there, the flex pipe should give you tones of clearence........ unless you got that sweed 6'' oil pan extender......
Old Mar 21, 2007 | 10:53 AM
951dc5's Avatar
Default Re: (M2B4)
my usdm manifold does fit except for the downpipe. i guess maybe getting a 5th gen header will fit but will need to do extra welding due to pipe shortage. my oil pan is stock, no extender or aftermartket. thanks and let me know if i need anything else.
deathfrost89
Sep 21, 2007 08:23 PM
patastinky
Mar 15, 2004 06:02 PM
Behan
Feb 26, 2004 08:49 AM
H22A EG6
Feb 5, 2004 07:29 AM
