is the WW RS kit direct bolt on or does it require molding/shaving??
Old May 23, 2002 | 03:18 PM
Neospite's Avatar
Default is the WW RS kit direct bolt on or does it require molding/shaving??
Old May 23, 2002 | 03:35 PM
projectcrx's Avatar
Default Re: is the WW RS kit direct bolt on or does it require molding/shaving?? (Neospite)
no molding no shaving you gotta drilll some holes
Old May 23, 2002 | 03:47 PM
Denny317's Avatar
molding/shaving would make the kit look a lot better though.
Old May 23, 2002 | 05:58 PM
xXx Justin xXx's Avatar
i had a whole **** load of shaving and trimming, a lot of holes to drill.....and mine is a real all eurethane ww kit. have fun!
Old May 23, 2002 | 06:02 PM
90civichbsi's Avatar
Default Re: is the WW RS kit direct bolt on or does it require molding/shaving?? (.:Rice-killa:.)
itll fit on ok w/o shaving, but if ya want it fittin perfect u will have to do a lil shavin.
ww redid thier molds since i got my bumper so the new ones should fit alot better
Old May 23, 2002 | 06:05 PM
Ltech's Avatar
Default Re: is the WW RS kit direct bolt on or does it require molding/shaving?? (90civichbsi)
I had to do a little adjustment in the rear to make the bumper fit. Other than that it's easy. Take your time though.
Old May 23, 2002 | 06:13 PM
tunedcivic's Avatar
Default Re: is the WW RS kit direct bolt on or does it require molding/shaving?? (Ltech)
****...lots of work to get the front bumper right on the hb...especially under the hood, near the corners, and near the lights. side skirts need to be molded or the tape will peal, and the caps on the back are usually big...good luck. lots of drilling too, especially if u wanna keep ur bumper frame support, and have fyun with the gap under the headlight on the hb.
Old May 23, 2002 | 06:33 PM
KiddieRydesCRX's Avatar
Whatever you do, don't mold your kit to the body. It'll crack for sure, unless your car is a trailer queen! You may have to do some trimming/modifying to the kit itself to make it work, but WW is usually pretty good.
Crxer
25
Jul 6, 2003 05:54 PM
tdaccord
Jan 7, 2003 07:10 PM
allmotorEG-SI
Apr 15, 2002 04:48 PM
phatcivic99
Mar 10, 2002 06:25 AM
Cryptopsy
Jan 10, 2002 08:26 AM
