Dropping The Car...
I had a question about dropping the car... I have a 94 Accord 4Dr Ex and when I got it, it was already dropped about 2.5 inches. And since lately Ive been rubuilding the head, I notice that when I took of the tires the inside of them were starting to wear out and you can start to see the little wires. Does anyone know that if dropping the car it makes the tires like that becuase it tucks in or could it be that the springs were cut out and thats why it tucks?
Could be. My dad took it to his friend's shop today and said that the springs were cut out. And said that I need some kits for the suspension so that the wheel can be straight verticle...
Well to tell you the truth im pretty sure its just the camber kit that needs to be put in becuase that has a negative pull on my tire and when i put them in it will straighten it out. and then ill get new tires and on the long run get springs
get your toe set at 0 or lower, and it should stop most of the tire wear.
cut springs is a different story. not only does it make your car ride horrible and bounce all over the place, but it could have a very negative affect on handling, which could be dangerous. at least replace them with something like eibach.
Accord-Guy
Suspension & Brakes
10
Apr 20, 2008 08:54 PM
hondaracin24
Aug 27, 2004 08:28 AM
