AEM pulley problem maybe????
Old Mar 17, 2007 | 06:59 PM
racer181's Avatar
Default AEM pulley problem maybe????
I just installed a set of AEM pulley's and my power steering pump is really loud now and i've loosened and tighten the belt and it's stilll loud. Is this normal? __________________
Racer181
181st Fighter wing
Crew Chief F-16C 86-0258
"My other Prelude is an F-16"
Old Mar 17, 2007 | 07:22 PM
Hawkze_2.3's Avatar
Default Re: AEM pulley problem maybe???? (racer181)
The pump is probably going bad or you are low on fluid.
AEM pullies really don't do anything good or bad.
Old Mar 17, 2007 | 07:29 PM
92blkJDMh22's Avatar
i vote fluid..... is your idle jumping at all when you turn the wheel while sitting still?
Old Mar 17, 2007 | 08:18 PM
racer181's Avatar
the pump is fine. But fluid keeps bubbling up out of the resivoir. At idle it's not so bad but when i turn the wheel it started screaming like a skool girl
Old Mar 18, 2007 | 05:09 AM
is it the pump that is screaming, or the belt...... maybe the pully is wrong and when pressure builds up in the system, it puts stress on the belt causing it to squeal due to improper tightening.... i dont know..... just a though
Old Mar 18, 2007 | 10:10 AM
racer181's Avatar
Default Re: (92blkJDMh22)
It's now more of an issue when i turn the wheels. The pump (or something somewhere in the system) is screaming. it's kinda like a waaaaaaaa sound.
Old Mar 18, 2007 | 10:16 AM
ludekid4323's Avatar
Default Re: (racer181)
mine does the same thing on cold mornings. After school I have to waite for 5mins before pulling out of the parking lot or else all the other kids look at me like my cars going to explode...I just tell em' its a blower
Old Mar 18, 2007 | 10:25 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racer181 &raquo;</TD></TR><TR><TD CLASS="quote">It's now more of an issue when i turn the wheels. The pump (or something somewhere in the system) is screaming. it's kinda like a waaaaaaaa sound.</TD></TR></TABLE>
Well, the cheapest thing to do right now is re-tension the belt and see if that fixes it.
Old Mar 18, 2007 | 10:33 AM
fastlude69's Avatar
if your fluid is bubbling are you sure you have honda powersteering fluid in their
Old Mar 18, 2007 | 12:48 PM
racer181's Avatar
Default Re: (fastlude69)
Yes it's honda power steering fluid. I'm gonna put the OEM pulley back on and see. So let's hope the p/s pump didn't go bad.
Old Mar 18, 2007 | 02:54 PM
racer181's Avatar
Problem solved. There was an air leak in the system. I R&I'd the feed line and all my problems were solved.
Old Mar 18, 2007 | 03:54 PM
thats good, Ill have to do the same
darkfx
Mar 13, 2014 11:39 AM
cityofcaterpillars
Apr 27, 2010 11:49 AM
JBirch_97Prelude
May 17, 2009 09:11 PM
lmedina
Oct 17, 2004 01:23 PM
