S2000 steering wheel
now that you mention it, I think I remember that happening to me for a little while right after the install.
funny thing is, it either went back to normal or I got used to it after a while....I haven't even thought about it since the install.
I will confirm after the next time I am out for a drive.
That does not sound right. The turn signal is not connected to the steering wheel /airbag / cruise control. I did it on my 2001 and had no problems.
did you line up the two notches on the steering wheel to the steering hub. and if your car is a sh, did you make a new notch to fit the 3 notch that is on the sh hub?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamadiscool »</TD></TR><TR><TD CLASS="quote">....u should AT LEAST post some pics...
Calling hu......... Calling hu......!!!!!!!! Dude, any w0rd on your 4thGen Swap/Experiment???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowsh »</TD></TR><TR><TD CLASS="quote">did you line up the two notches on the steering wheel to the steering hub. and if your car is a sh, did you make a new notch to fit the 3 notch that is on the sh hub?</TD></TR></TABLE>
Can you go into alittle more detail about that I want to hear about this
ok since you have a sh you have 3 notches in your steering hub instead of 2 for the base. you have to cut a notch for that 3rd one, after you do that your fine.
