JHP OBD1 Harness problems!
Old Mar 17, 2007 | 03:09 PM
LSVTEC 91 Civic's Avatar
Banned
Default JHP OBD1 Harness problems!
Okay, I hooked up the harness, sent the additional harness extension wires to o2 sensor, VTEC signal, VTEC pressure switch.
I now have these following trouble codes...
6 ECT
9 CYP
20 ELD Circuit
21 VTEC Signal
22 VTEC Pressure
36 (Traction Control
Everything seems to be hooked up properly. Anybody else have problems with a JHP conversion harness?
Modified by LSVTEC 91 Civic at 7:19 PM 3/17/2007
Old Mar 17, 2007 | 05:29 PM
Banned
Help!
Old Mar 17, 2007 | 07:55 PM
Rywire's Avatar
Default Re: (LSVTEC 91 Civic)
did you allready have prewired vtec for obd0? Make sure your ecu pins are all in stock locations before you use a jumper
Old Mar 18, 2007 | 07:37 AM
Banned
Default Re: (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">did you allready have prewired vtec for obd0? Make sure your ecu pins are all in stock locations before you use a jumper</TD></TR></TABLE>
Yes I did. I'm just curious if there are any known issues with the JHP harness. If not, I'm going to replace my OBD0 harness.... It's a rat's nest.
Pagley
Feb 22, 2011 08:25 PM
1SiC 3DR
Sep 23, 2009 08:41 PM
1BADEGDC2
Feb 9, 2009 07:25 AM
quicksol95
Mar 19, 2004 01:50 PM
NatedoggAZ
Nov 9, 2003 08:51 AM
