could i use si wiring
Old Mar 17, 2007 | 02:02 PM
bluelsvtecda9's Avatar
Default could i use si wiring
i want to know if i can use my wiring to drop a b20 i have a 91 dx converted to a si would i have to change anything or do i have to mod it
Old Mar 17, 2007 | 02:43 PM
K20EF8Dx's Avatar
Default Re: could i use si wiring (bluelsvtecda9)
EDIT: Sorry missed the part were you said its already converted...
Old Mar 17, 2007 | 02:49 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: could i use si wiring (K20EF8Dx)
By converted to SI do you mean it's wired for MPFI?
if so and you are planning to run the b20 as an obd0 motor you can get away with out wiring hassles.
I do reccomend going to obd1 while it's all apart http://www.boomslang.us
Old Mar 17, 2007 | 04:10 PM
Default Re: could i use si wiring (Ace$nyper)
yeah its mpfi its a dx but i got the whole si harness that i picked up at a junkyard around my area for $25 bets splicing wires anyway to make obd1 i have to get all the plugs do they all have the same wires as obd0
Old Mar 17, 2007 | 07:58 PM
Rywire's Avatar
you have to use a dx engine harness, the si harness can only be used for parts
Old Mar 18, 2007 | 01:41 PM
Default Re: could i use si wiring (droppedcrxsi)
it has the whole si wiring it is already mpfi i went to the junkyard they had a complete si hatch so i took out the wiring and put it in my dx
Old Mar 18, 2007 | 02:20 PM
HondaHeddie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">you have to use a dx engine harness, the si harness can only be used for parts</TD></TR></TABLE>
he already went the hard way on the conversion.
to the thread owner:
I would convert to obd1 as well if I were dropping a B-block in.
so if you are currently obd0 the recommendation is yes
unless you are gonna run that B obd0
entoy
Aug 18, 2013 04:36 PM
y7hatch
Sep 9, 2004 05:41 PM
qcoffey
Jun 29, 2003 07:18 PM
Hybrid CRX
11
Jul 7, 2002 07:07 PM
maximedx
Jan 13, 2002 07:24 PM
