Stock fuel pump =====> 255 lph
Old Mar 17, 2007 | 01:20 PM
itr1244's Avatar
Default Stock fuel pump =====> 255 lph
i just installed the walbro fuel pump and the car was tuned with stock fuel pump.
and do i need to re-tune the car after this mod or ??
any ideas?
Old Mar 17, 2007 | 02:09 PM
neo_'s Avatar
Default Re: Stock fuel pump =====> 255 lph (itr1244)
Fuel Pressure Regulator adjustment will be needed.
Correct me if I'm wrong.
Old Mar 17, 2007 | 02:20 PM
itr1244's Avatar
Default Re: Stock fuel pump =====> 255 lph (neo_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">Fuel Pressure Regulator adjustment will be needed.
Correct me if I'm wrong. </TD></TR></TABLE>
you're right.
i had to lower the pressure a little bit.
i had it set at 55-56 psi and after the new pump it was at 60+
Old Mar 17, 2007 | 02:48 PM
vtec.dc2's Avatar
why did you install walbro to begin with? its probably best to retune.. i ran stock injectors and ecu on walbro, car had no problems but i just needed to get from A to B
Old Mar 17, 2007 | 03:08 PM
neo_'s Avatar
Default Re: Stock fuel pump =====> 255 lph (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">why did you install walbro to begin with? its probably best to retune.. i ran stock injectors and ecu on walbro, car had no problems but i just needed to get from A to B</TD></TR></TABLE>
Nitrous??
Plan to upgrade to bigger injectors?
Old Mar 17, 2007 | 05:05 PM
itr1244's Avatar
i had the pump sitting around in my room and i had my motor done last summer and got it tuned.. and i thought i might as well install it.
Old Mar 18, 2007 | 10:26 AM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">
so if you don't have any problems using stock fuel pump.. go back to using stock fuel pump..
can this mess up your a/f if you don't retune.. probably..
on same hand.. i wouldn't waist money for retune just because i added walbro pump, wait until you get some more mods, then install walbro pump and retune at once.
Old Mar 18, 2007 | 11:55 AM
itr1244's Avatar
yeeh that makes sense but i need my car retuned some time soon anyways..
i think it might make the car run a little rich overall but i am not sure.. dyno should tell me the answer
champLSinteg
Sep 20, 2006 04:39 PM
RTW DC2R
Sep 27, 2005 01:46 PM
tweekerz
Jul 25, 2005 05:15 AM
full Circling
Jul 9, 2005 11:28 PM
SupaFly_Honda
Dec 22, 2003 02:26 PM
