installed new in. manifold & TB, idle is way high. help???
Old Mar 17, 2007 | 07:46 AM
1baddturbosi's Avatar
Default installed new in. manifold & TB, idle is way high. help???
installed a victor X in manifold & bb throttle body, and it idles at 2000 rpm. also i when i go press the gas the throttle seems to stick. need advice
Old Mar 17, 2007 | 05:36 PM
Turbocivic94's Avatar
Default Re: installed new in. manifold & TB, idle is way high. help??? (1baddturbosi)
u probably have vacume leak
Old Mar 17, 2007 | 06:00 PM
Muckman's Avatar
Moderator in Chief
Sounds like you have a vac leak or your throttle cable is too tight.
Old Mar 17, 2007 | 06:28 PM
DaveF's Avatar
Default Re: installed new in. manifold & TB, idle is way high. help??? (Muckman)
im going to go with vacum leak between the tb/intake manifold for 300, alex.
93turbo16's Avatar
Default Re: installed new in. manifold & TB, idle is way high. help??? (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">im going to go with vacum leak between the tb/intake manifold for 300, alex. </TD></TR></TABLE>
Old Mar 17, 2007 | 08:13 PM
zexxbo's Avatar
Default Re: installed new in. manifold & TB, idle is way high. help??? (93turbo16)
you might need type r throttle cable bracket?
Old Mar 18, 2007 | 09:25 AM
jDMJeRk's Avatar
Spray some break clean around your tb and see if you can find the leak if any. Did you adjust the idle at all on the new tb after you installed it?
Old Mar 18, 2007 | 11:00 AM
TypeSLO's Avatar
check TB cable? possible vac leak? pull charge pipe off TB and block it so the motor shuts off. if it doesn't shut off, you've got yourself a vac leak.
Old Mar 18, 2007 | 07:43 PM
batboyvaj's Avatar
take off your intake tube and you should see 1 or 2 holes (depends on year of motor). with your car running, cover the hole with your finger and your car should stop running. if it doesn't, then you have a vac leak somewhere. if you cover it and it dies then maybe the iac valve is bad?
Old Mar 18, 2007 | 09:27 PM
Default Re: (batboyvaj)
i bought the manifold used and it already had a iacv on it. i took it off and put on the one that was on my stock manifold cause i dunno if it workd or not.
i messed around with the idle screw like forever thinking it was the issue.
ill take off the charge pipe and put my hand on the tb to see if my motor dies.
Old Mar 19, 2007 | 04:06 PM
Default Re: (1baddturbosi)
the motor almost dies, but doesnt. sooo i must have a vacuum leak.
imbest123
Jul 27, 2012 08:59 PM
si90rex
Jun 24, 2007 07:12 PM
tigueremalo
31
Jun 13, 2006 03:53 PM
Sideshow9090
11
Nov 13, 2005 07:35 PM
civic dx
Aug 25, 2004 03:10 PM
