Cooling fan died. Considering FAL upgrade. Need advice.
Like the topic says.. one of the fans on my 2001 ITR died and I need a replacement ASAP. A new oem fan motor runs about $166 so I figure this is a great opportunity to grab some FAL fans.
The obvious question is, what's the flow rate of the OEM fan ?? Then, what is the flow rate of the FAL fans ?? Is there another competitive alternative ?? SPAL maybe ??
Please shoot your comments and suggestions. Also, places to buy or if you're selling one, LMK ASAP !!
Thanks !!
Thanks !!
What about generic fans, save yourself like $200.
https://honda-tech.com/zerothread?id=1473722
I haven't discarded generic. I can get those fans locally for a similar price and I very well may end up going that way. I'm really testing the water to see if I can go with some FALs for added performance and the o-so-needed bling
Also, the generics need wire spllicing and putting ties through the radiator, which is not a big deal but something to consider. Yes, I'm picky I know.
Lastly, assuming I go with 12" fans, the generics flow about 1550cfm vs 2000cfm for the FALs. That's almost a 20% improvement for the FAL.
What's the flow rate of the OEM fans ??
Modified by iperez at 2:02 PM 3/17/2007
or this: https://honda-tech.com/zerothread?id=936861
theres a point in every product type, where after certain price range you're not geting that much better of a deal.. when it comes to fans, it starts at $50
I've been happy with my FAL. Frees up alot of space.
It is a little noisier than OEM but moves ALOT more air.
i live in phx az and havent used a fan period in 6 years of driving.
in lou of saint pattys days... theyre a bunch of malachy
get an oil cap if you want bring
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious »</TD></TR><TR><TD CLASS="quote">i live in phx az and havent used a fan period in 6 years of driving.
get an oil cap if you want bling</TD></TR></TABLE>
fixed.
fixed.
I can't believe how good that looks
. Clean is an understatement
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 00-0477 »</TD></TR><TR><TD CLASS="quote">
. Clean is an understatement<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 00-0477 »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket »</TD></TR><TR><TD CLASS="quote">I can't believe how good that looks
Exactly my point .. you can't beat form and function in the same product ...
. Clean is an understatement</TD></TR></TABLE>
tyvm.
tyvm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R »</TD></TR><TR><TD CLASS="quote">FAL will even fit with a larger aftermarket radiator.
http://www.flickr.com/photos/47305622@N00/321916612/</TD></TR></TABLE>
mmmmm
bling rad with fal fans and anti-reversion chambered header
tasty
mmmmm
tasty
just get a slimline fan for 55 and call it a day.
I run one on my boosted R and its great, temps have never gone above 203.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R »</TD></TR><TR><TD CLASS="quote">FAL will even fit with a larger aftermarket radiator.</TD></TR></TABLE>
But it won't fit if you have A/C. I still have a FAL dual fan to sell because it didn't fit my Koyo/SPOON header/A/C configuration.
-Victor
-Victor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 00-0477 »</TD></TR><TR><TD CLASS="quote">I've been happy with my FAL. Frees up alot of space.
are those dual 10, 12 or 14?
</TD></TR></TABLE>are those dual 10, 12 or 14?
They are 12".
Looking at their website. I think they discontinued yellow.
http://www.flex-a-lite.com/aut....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97 TYPE-R 312 »</TD></TR><TR><TD CLASS="quote">But it won't fit if you have A/C. I still have a FAL dual fan to sell because it didn't fit my Koyo/SPOON header/A/C configuration.
-Victor</TD></TR></TABLE>
I was under the impression that the left fan worked just fine as the A/C fan. Thats what their literature seems to say.
Erik, who's curious about that answer to this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS »</TD></TR><TR><TD CLASS="quote">
Erik, who's curious about that answer to this.</TD></TR></TABLE>
dunno.
Both of my fans work for cooling only. I'm not sure if that would be diff if I had the AC still hooked up.
dunno.
If I stand in front of my car, facing the engine compartment, the fan to my left side is the one that failed. I was able to notice the failure because a) the A/C stopped cooling and b) the temp gauge was showing hotter than normal. So, at least in my case, I am making it a point to keep both fans working.
On a side note, if the FAL fans are actually smaller than oem, why would this be a problem with keeping the A/C ?? Note that I am using an OEM radiator for the time being.
PM'd you Victor. Anyone else have a set of FAL fans up for sale ?? I need this ASAP.
