CEL ? code #9 CYP-cylinder sensor??? any help!!!
Old Mar 16, 2007 | 02:32 PM
sicegcivic's Avatar
Default CEL ? code #9 CYP-cylinder sensor??? any help!!!
my buddie has a crx, b20vtec, converted to obd1 bla bla bla... car wont idle at steady rpm, revs are bogged, pain to drive... car ran great for close to 2 yrs till one day... only code is code#9 cylinder sensor.... have no idea what the problem could be??? any help appriciated... checkin here before i start troubleshooting!!!
thanks
-Don
Old Mar 16, 2007 | 02:55 PM
1ludeEK's Avatar
Default Re: CEL ? code #9 CYP-cylinder sensor??? any help!!! (sicegcivic)
had the same problem. my cams were to big for my compression. check the dizzy the cylinder position sensor is in the dizzy. try another dizzy
Old Mar 16, 2007 | 03:05 PM
rEnZ94tEgGy's Avatar
Default Re: CEL ? code #9 CYP-cylinder sensor??? any help!!! (1ludeEK)
took the works right out of my mouth. (check the dizzy, thats where the cps is )
Old Mar 16, 2007 | 06:19 PM
sicegcivic's Avatar
Default Re: CEL ? code #9 CYP-cylinder sensor??? any help!!! (rEnZ94tEgGy)
the dizzy is brand new (bearings went bad in last one and had to replace) however it has an msd 6al and blaster ss installed (was installed when swap put in)... could it be something to do with that??? problem started one day randomly few weeks after dizzy change... and like i said, nothing was changed but the dizzy ???
-checked timing today and hard to get an exact setting because of the idle problem??
-possible vaccume leak?
-TPS sensor???
thanks again
-Don
Old Mar 16, 2007 | 07:34 PM
stealthmode62's Avatar
I had the same issue a couple weeks ago. The screw came off that holds the rotor on and spun around inside the dizzy and fucked up the sensor. The rotor stayed on and car ran still.
Take the cap off the distributor and you'll see a black square box thingy that has a small piece of metal coming out of it. It works much like the "points" on the distributor cap when the rotor comes around and brushes them. I'd try to just replace that sensor from another distributor. Other models' sensors could possibly work i would think.
Old Mar 16, 2007 | 10:46 PM
sicegcivic's Avatar
Default Re: CEL ? code #9 CYP-cylinder sensor??? any help!!! (stealthmode62)
will try that tomorrow in the morning... thanks again for the help!!!! ill let ya know what happens!!
thanks
-Don
Old Mar 17, 2007 | 05:14 PM
sicegcivic's Avatar
bump... still havent found problem... went ahead and replace rotor and spark plugs cuz they fouled since the car is running sooo bad!!!
Old Mar 18, 2007 | 10:47 AM
sicegcivic's Avatar
bump! workin on car right now!!!
Old Mar 18, 2007 | 10:34 PM
sicegcivic's Avatar
still have problem BUMP!!
Old Mar 20, 2007 | 12:54 PM
sicegcivic's Avatar
waiting on some parts... still not fixed BUMP
Old Mar 20, 2007 | 01:04 PM
ALLMOTORH22A's Avatar
Default Re: (sicegcivic)
check to make sure ur timing marks r lined up correctly.. the cams and the crank might not be lined up properly.. TDC the motor and make sure the marks line up.. make sure u TDC the crank first than check the marks on the cam gears.. they might be off
Michael House
Oct 2, 2015 02:35 PM
AZintegragsrT
Jul 24, 2009 09:03 AM
91-lsvtecsi
Sep 16, 2007 06:18 PM
poopoohead
Aug 8, 2006 05:24 PM
wickedxboi
Jul 28, 2002 08:34 AM
