D16y8 High Comp Build - Need info double checked
Old Mar 16, 2007 | 11:56 AM
ksprelude01's Avatar
Default D16y8 High Comp Build - Need info double checked
I have a d16y8 motor
Items buying
-pm6 (ZC) Pistons
-.079mm cometic head gasket
-zex stage 2 cam
The compression comes out to be around 11.2 to 1
I checked several compression calc's I just want to make sure its some where around that and not higher than 11.5. And I was wondering if anyone knows any HP numbers from other people doing the same build. I've been researching for a while and didnt get any def #'s.
Thanks Keith
Old Mar 16, 2007 | 11:59 AM
coneheadsracing's Avatar
Default Re: D16y8 High Comp Build - Need info double checked (ksprelude01)
In for some responses. Doing a similair build, already have my pistons coming, but from what i've read, it should be around the high 12's. I'm personaly hoping this is correct.
Old Mar 16, 2007 | 12:15 PM
Ya with the stock head gasket it is that high. Just wanted to make sure that the .074mm head gasket will drop it to a more streetable level.
Old Mar 16, 2007 | 12:20 PM
Default Re: (ksprelude01)
ah yup, my bad... reading owns me
Old Mar 16, 2007 | 12:54 PM
spun Vtec's Avatar
Default Re: (coneheadsracing)
up to 140 whp would be my guess with a good tune
Old Mar 16, 2007 | 01:58 PM
Awesome, Its more hp than i have now, that all I wanted. Thanks for the info.
My car made a hole 113hp with 4-1 header, no cat and the silencer in(2 hp less with it out) and that on a 208,000 mile motor!
But Now with the cat back on and a S2000 muffer I'm hopen that this motor work give the car a little more of a kick again.
Its just the c/r that I am worried about. I just dont want to be pinging all over the place because of the compression being to high.
Modified by ksprelude01 at 5:09 PM 3/16/2007
Old Mar 16, 2007 | 04:45 PM
ONEcam's Avatar
i got a brand new bisimoto header for sale..if u need an header good luck on the build
Old Mar 16, 2007 | 04:52 PM
I already have a 4-1 header, Thanks though
Old Mar 19, 2007 | 06:05 PM
Eyal 951's Avatar
I have a similar build in my daily driver:
https://honda-tech.com/zerothread?id=1717242
https://honda-tech.com/zerothread?id=1759605
Feel free to contact me for more info.
khmoe
Jan 14, 2009 02:05 PM
CALC!_JUST_du_IT!
May 12, 2008 10:44 PM
ZCpoweredCRX
Apr 26, 2004 08:32 PM
Clutch101
Nov 14, 2002 03:21 PM
