heart transplant
Old Mar 16, 2007 | 09:46 AM
donger's Avatar
Default heart transplant
here's some pics of what ive been workin on over spring break
more pics will be up as i finish up
Old Mar 16, 2007 | 10:03 AM
high_revs's Avatar
looks good i hope you converted it to manual tensioner
Old Mar 16, 2007 | 10:42 AM
ethereal2pt2's Avatar
Default Re: (h2b_eg8)
nice work.
maybe a wire tuck is in order?
Old Mar 16, 2007 | 04:08 PM
flyrod's Avatar
Default Re: (_BB6)
Good way to spend spring break. Looks like a JDM H22?
Old Mar 16, 2007 | 04:17 PM
snobordboy's Avatar
Moderator
Default Re: (flyrod)
Awesome, I just did the same thing (minus painting the bay) 4 months ago. You will lovvve the car with the H22 in it! I would recomend doing some wire tuck as well, I did the passenger side of my engine bay a bit, and like the look way better!
Old Mar 16, 2007 | 04:47 PM
Default Re: (snobordboi)
how long did that take you?
Old Mar 16, 2007 | 08:14 PM
h22silvia's Avatar
good job its pretty much bolt on in there easy swap
Old Mar 17, 2007 | 01:28 AM
donger's Avatar
Default Re: (h22silvia)
thanks for the comments. unfortunately i didnt do a manual tensioner swap. didnt do enough research about it before starting. yes, it is a JDM H22 with M2B4 (LSD) tranny. also, no wire tuck. as much as i like the way wire tucks look, i didnt really wanna go through the trouble to relocating a bunch of stuff. i'm just happy that my engine bay is the same color as the rest of the car now.
Old Mar 17, 2007 | 05:54 AM
high_revs's Avatar
atleast you got lsd look into a manual tensioner soon
Old Mar 17, 2007 | 10:57 AM
s_vares's Avatar
why do a manual tensioner?
that makes no sence, too much work for nothing.
Old Mar 17, 2007 | 11:05 AM
esedulerp5tenin's Avatar
Default Re: (s_vares)
looks like your project is coming along better than my turbo spring break project
looks good.
Old Mar 17, 2007 | 11:09 AM
red92si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s_vares &raquo;</TD></TR><TR><TD CLASS="quote">why do a manual tensioner?
that makes no sence, too much work for nothing.</TD></TR></TABLE>
The Auto Tensioner is known to fail on engines with modified valvetrains and I've seen them fail on even stock engines. The H23 Manual Tensioner will not fail. Its worth doing for the peace of mind. Especially if you have the engine out of the car already. Its a simple procedure if the engines out, much more labor intensive if its in.
Old Mar 17, 2007 | 12:20 PM
high_revs's Avatar
because the hydro ones tends to fail, and if it does fail, say bye bye to your valves minimal...
Old Mar 17, 2007 | 12:23 PM
s_vares's Avatar
I will have to say I can se it failing on a modded car but ive never had an un modded car come in with it defective. CHange it with your timing belt, its only 75 bux.
Old Mar 17, 2007 | 12:32 PM
kulrevon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2b_eg8 &raquo;</TD></TR><TR><TD CLASS="quote">
because the hydro ones tends to fail, and if it does fail, say bye bye to your valves minimal...</TD></TR></TABLE>
This is untrue. the h22 is a noninterference engine until vtec. So as long as you are not in vtec when the timing belt snaps you engine will be fine.
The manual tensioner is no more work than the auto.
Old Mar 17, 2007 | 03:02 PM
high_revs's Avatar
Default Re: (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">
This is untrue. the h22 is a noninterference engine until vtec. So as long as you are not in vtec when the timing belt snaps you engine will be fine. </TD></TR></TABLE>
so if it does break in vtec, there goes your valves, how is my statement not true? ok now what if you have cams... what if you have different/higher comp pistons, theres a lot of things to take into consideration...especially once you start modding...i rather be safe with fail free manual tensioner, then taking chances with hydro....i would never ever run a hydo tensioner, but that just me.
JSJ BROTHERS
Apr 26, 2010 11:16 AM
imacoolkid
Mar 12, 2008 01:20 PM
JSJ EG6
Apr 10, 2007 10:25 AM
VIS250P
Jun 9, 2005 01:19 PM
HyBriDcxR
Apr 15, 2004 01:34 PM
