high compression pistons
i need help! last week i went to smog my car of course i didnt pass. i jus rebuild my motor with jdm itr pistons. i pass everything else with flyin colors , but the one i didnt pass is the emission part. i was runnin too high of emission can the itr can cause that to happen. also i'm running too rich. i have 2600 miles on the rebuild. have any had a problem like that in california. what can i do to pass the smog. i dont want to do a illegal smog. that how shady smog tech get money and i'm not goin to fall for it. oh i forgot i have 98 integra gsr. please give helpful ideas and opinons.
Have a chip burnt, cut some fuel out so you are not running so rich. (have somone do this that knows what they are doing. Have the car on a wideband)
thanx for the ideas, this monday i'm goin to smog it again to see if i will pass. i will let you kno if i pass or not.
what do you mean you were "running too high of emissions"?
what was high c0? nox? hc?
i beleive if you lean the engine out it will cause higher Nox..
im not a smog tech, so someone chime in.
It's not the pistons, its the tuning. Well, I guess it is the pistons if you refuse to tune. Anytime you change internal engine dynamics you need to tune. Don't you want all the performance gains your car deserves, and reliability, and gas mileage, and reduced emissions,...then tune it.
Or you need a new cat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nokturnal_munkeeboy »</TD></TR><TR><TD CLASS="quote">can those itr pistons cause me too high of emissions. that the only thing i have in my car. everything else is stock.</TD></TR></TABLE>
yeah it raises "Emissions" also running lean raises emissions and running rich raises emissions..look at your smog printout and tell us whats high and failed..
it also could be a bad catlytic converter, bad o2 sensor etc..
could be misfire, but higher combustion temps (higher compression) cause higher hc,
its not failing by much bro...i would throw some cam gears on there,if you dont already have some and retard the intake cam a few degrees..this will help lower your static compression a bit... and will help alot on those hc's.
guess what yall i pass smog yesterday.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nokturnal_munkeeboy »</TD></TR><TR><TD CLASS="quote"> i need help! last week i went to smog my car of course i didnt pass. i jus rebuild my motor with jdm itr pistons. i pass everything else with flyin colors , but the one i didnt pass is the emission part. i was runnin too high of emission can the itr can cause that to happen. also i'm running too rich. i have 2600 miles on the rebuild. have any had a problem like that in california. what can i do to pass the smog. i dont want to do a illegal smog. that how shady smog tech get money and i'm not goin to fall for it. oh i forgot i have 98 integra gsr. please give helpful ideas and opinons.</TD></TR></TABLE>
my motor is built, the only was wrong with my car was the o2 sensor and catalytic converter. my head is built and bottom end is built, thanks for all the info to help me out
weekendboost
Jan 11, 2013 04:43 AM
boredracer408
Jan 9, 2004 11:39 PM
