Trans Slipping
How many miles?
Whens the last time you changed the fluid?
Drain the old fluid and try replacing it with Lucas Transmission fix, 1 bottle should be ok, then the rest with regular transmission fluid, or if its bad, 2 quarts of Lucas trans fix then the rest trans fluid...
