Stock SI endlinks...can it be removed? Will Blox aftermarkets fit?
Old Mar 16, 2007 | 08:14 AM
Si_chRis's Avatar
Default Stock SI endlinks...can it be removed? Will Blox aftermarkets fit?
Kinda slow in the suspension forum so I figured I'd post here.
So I tried chaging my LCA's before and my stock SI endlinks were stuck to one of my stock LCA's. The nut kept spinning and wouldn't come out. Is there a head bolt on the other side to grab to keep the nut from spinning?
And in case I don't get it out, will Blox aftermarket endlinks fit on my stock SI swaybar?
Old Mar 16, 2007 | 08:42 AM
Si_chRis's Avatar
Default Re: Stock SI endlinks...can it be removed? Will Blox aftermarkets fit? (EM1_ChRiS)
anyone?...will the Blox endlinks fit at least?
Old Mar 16, 2007 | 08:47 AM
zerovandez's Avatar
they'll fit.
Old Mar 16, 2007 | 08:51 AM
kaiba's Avatar
99.9% sure it will fit
Old Mar 16, 2007 | 08:55 AM
le0ftw's Avatar
KOBE IS GOD
FYI: I got a CTR sway if you want to purchase one yes they will fit.
Old Mar 16, 2007 | 08:56 AM
Si_chRis's Avatar
Default Re: Stock SI endlinks...can it be removed? Will Blox aftermarkets fit? (kaiba)
Ok thanks. But before I order new endlinks, is there a head bolt to grab on the endlink to keep the nut on the other side of the lca from spinning freely?
Cause if so, I might just keep my stock endlinks.
Old Mar 16, 2007 | 09:32 AM
Takymoto's Avatar
I'm a Jackass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1_ChRiS &raquo;</TD></TR><TR><TD CLASS="quote">Ok thanks. But before I order new endlinks, is there a head bolt to grab on the endlink to keep the nut on the other side of the lca from spinning freely?
Cause if so, I might just keep my stock endlinks.</TD></TR></TABLE>
mine was doing that too..I had to cut the endlink off..
and I'm not very happy with my blox endlinks
Old Mar 16, 2007 | 09:34 AM
electron_si's Avatar
Default Re: Stock SI endlinks...can it be removed? Will Blox aftermarkets fit? (Takymoto)
blox endlinks suck. What swaybar are you running?
there is no way to get those endlinks out without messing them up. there is a ball that is attached to the stud that you say keeps spinning. the ball is in a plasic cup inside the enlinke. if you put too much pressure on it, it will snap.
if your going with an aftermarket sway, go with function 7 endlinks
Old Mar 16, 2007 | 09:37 AM
Takymoto's Avatar
I'm a Jackass
Default Re: Stock SI endlinks...can it be removed? Will Blox aftermarkets fit? (electron_si)
i would just replace the si endlinks myself nothin better then oem
Old Mar 16, 2007 | 10:07 AM
Si_chRis's Avatar
I have a stock SI sway bar. I was thinking of getting an ITR but if I can just replace the endlinks when I get my LCA's on, I'll just do that.
Old Mar 16, 2007 | 10:12 AM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takymoto &raquo;</TD></TR><TR><TD CLASS="quote">
and I'm not very happy with my blox endlinks </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by electron_si &raquo;</TD></TR><TR><TD CLASS="quote">blox endlinks suck. What swaybar are you running?
if your going with an aftermarket sway, go with function 7 endlinks </TD></TR></TABLE>
wo wo guys....can i get more info on why the blox endlinks suck?? i have gsr rear sway bar lying around and i might use the blox endlinks. All of this is going into my EJ8
Old Mar 16, 2007 | 10:21 AM
Takymoto's Avatar
I'm a Jackass
Default Re: Stock SI endlinks...can it be removed? Will Blox aftermarkets fit? (bmoua)
mine clunk like a ****
Old Mar 16, 2007 | 10:23 AM
Si_chRis's Avatar
I heard if you use nylon washers, the noises go away?
Old Mar 16, 2007 | 10:34 AM
aznpridelivin2o3_cg5's Avatar
ayoo EM1_ChRiS, your a newb
Old Mar 16, 2007 | 10:41 AM
Si_chRis's Avatar
Default Re: Stock SI endlinks...can it be removed? Will Blox aftermarkets fit? (aznpridelivin2o3_cg5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznpridelivin2o3_cg5 &raquo;</TD></TR><TR><TD CLASS="quote">ayoo EM1_ChRiS, your a newb </TD></TR></TABLE>
you're a noob Frank....refer to your post count...lol...did u finish waxing ur car?
Old Mar 16, 2007 | 10:51 AM
pdiggitydogg's Avatar
post count should have nothing to do with knowledge
There is an allen head in the em1 endlink...use that to get them off. If its stripped out...youre SOL and will have to cut them off.
Old Mar 16, 2007 | 10:55 AM
bmoua's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">post count should have nothing to do with knowledge
There is an allen head in the em1 endlink...use that to get them off. If its stripped out...youre SOL and will have to cut them off.</TD></TR></TABLE>
thats true brother...i have over 2,000 posts and honestly i consider myself a noob. You really learn from your problems that occur with your car, from there you trouble shoot, learn, and give out advice on HT haha...
Old Mar 16, 2007 | 10:58 AM
Si_chRis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">thats true brother...i have over 2,000 posts and honestly i consider myself a noob. You really learn from your problems that occur with your car, from there you trouble shoot, learn, and give out advice on HT haha... </TD></TR></TABLE>
yea true, but I know that dude personally, hes my friend...just messin with him and I think he's a noob
So I think I'll go with some other endlinks besides Blox, maybe go with the function 7's
Thanks guys, thread can be closed.
rubikscube
Sep 27, 2011 07:45 AM
bummax
Mar 28, 2011 10:14 AM
shortlid
Mar 17, 2008 09:06 AM
SamRi
Jun 6, 2007 05:48 AM
Si_chRis
Suspension & Brakes
Mar 16, 2007 02:03 PM
