92-95 audio console dimension help
Old Mar 16, 2007 | 06:28 AM
kaiba's Avatar
Default 92-95 audio console dimension help
Can anyone give the dimension of the auido console for the 92-95 civic double din slot. LxWxH
Thanks.
Old Mar 16, 2007 | 07:04 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: 92-95 audio console dimension help (kaiba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba &raquo;</TD></TR><TR><TD CLASS="quote">Can anyone give the dimension of the auido console for the 92-95 civic double din slot. LxWxH
Thanks.</TD></TR></TABLE>
I can't give any numbers, but I do know it's not quite a true double din. It's more of a 1 & 3/4 Din size. And it comes with a single din sized pocket...
Old Mar 16, 2007 | 07:25 AM
kaiba's Avatar
Default Re: 92-95 audio console dimension help (94eg!)
Oh well. Looks like i'll just have wait untill i get home and take the measurements.
Old Mar 16, 2007 | 10:24 AM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">
I can't give any numbers, but I do know it's not quite a true double din. It's more of a 1 & 3/4 Din size. And it comes with a single din sized pocket...</TD></TR></TABLE>
It's a true double din. I just fit my double din CRV 6-disc in-dash player in there. The only thing wrong with the fitment is the dash bracket and audio console frame in the back. I hacked the audio console frame, but the rear of the radio still touches the bracket slightly.
Old Mar 16, 2007 | 10:31 AM
kaiba's Avatar
Default Re: 92-95 audio console dimension help (BlueIntegraBoy)
Yeah... that's basically what i wanted to know. I wanna fit a double din lcd in there.
Old Mar 16, 2007 | 11:22 AM
_BEN_'s Avatar
The problem I had was not the dimensions of the opening but with how DEEP the hole is. You are going to have to bend a brace so you can stuff the head unit all of the way in.
You can see the pocket in the stock radio location. I just had it setting in there. When hammering 1st,2nd and sometimes 3rd it would pop out.
Old Mar 16, 2007 | 11:26 AM
kaiba's Avatar
Default Re: 92-95 audio console dimension help (_BEN_)
Maybe because your is JDM. LOL
Old Mar 16, 2007 | 01:06 PM
_BEN_ you had to hack the rear frame of the audio console as well as pound in the dash bracket? Cuz I tried installing a CRV double din and it hit both. I hacked off the frame, but still have to pound the dash bracket.
Old Mar 16, 2007 | 01:15 PM
_BEN_'s Avatar
Maybe your head units mounting depth is different because I only had to bend a metal support. No cutting.
The skeleton behind the dash is also a little different from lhd to rhd.
Old Mar 16, 2007 | 01:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BEN_ &raquo;</TD></TR><TR><TD CLASS="quote">Maybe your head units mounting depth is different because I only had to bend a metal support. No cutting.
The skeleton behind the dash is also a little different from lhd to rhd. </TD></TR></TABLE>
Yeah, the unit is pretty deep. I tried bending the frame, but it looked like **** when I was done with it. So I decided to chop it off, plus it gave me some extra room, although not enough. Well, when I get my harnesses to wire up the radio, I will attempt to pound the **** out of the dash bracket.
ap1$2k
Nov 10, 2007 07:20 PM
patrickdc4130
Jun 24, 2007 12:03 AM
graveltravel2
Mar 1, 2006 10:29 AM
Revtek 2
Jul 6, 2005 12:51 PM
Ag-Eng
May 20, 2004 07:22 PM
