Many parts. (NY)
Will consider shipping. 516-410-1739, please leave message if I miss your call and I'll get back to you. Thanks for looking.
-3 JE 9:1 compression .20 over pistons w/eagle rods (3 JE pistons on Eagle rods). These are used. $150, they are used but nothing wrong with them.
-Brand new 310 Rc injectors in box...make offer.
-OBD2 B series alternator for $50.
-OBD2 D series starter $50
-OBD2 D series dizzy $50-will also work on B series cause one of the arms was removed to do so.
-OBD2 D series alternator $50
-O2 sensors $15 each
-LS oil pan $40
-LS oil pick up tube $20
-LS baffle tray $20
-1998 Integra LS Ecu $75. (OBD2a)
-Got Integra power mirrors (94+tegs), they’re red. $50 takes them.
-Got Integra ignition with key $80 takes it, got a couple from 95,98 etc....
-1990-93 Integra ignition with key $50.
-I have 1998-2001 Integra headlights, got minor cracks in the back but the lens part are fine, they work with no problem. $75 takes them.
-1994-2001 Integra headlight wiper signal switches. $30
-Got a OBD1 P28 chipped with some program boost on it $125. Come try it out if you want to. Or just replace the chip with whatever you want.
- Eagle Crank $150 negotiable. ID # is 1835041772 and you can check it out here:
http://search.netscape.com/ns/...om%2F
Go to products then Honda, then cranks and look up the number on their list. Did spin a bearing but can be fixed.
516-410-1739
-LS oil pan $40
-LS baffle tray $20
516-410-1739
