What motor do I have?? Please help! Sorry, no pix...
Old Mar 16, 2007 | 02:23 AM
EF_PINOYGUY's Avatar
Default What motor do I have?? Please help! Sorry, no pix...
I'm trying to put this motor in my 90si crx....Please help me out peepz!...
Hi...I bought a motor from this importer, but does'nt have the d-numbers on it because there was no transmission...The guy told me it was a ZC..That is the only thing stamped on the block and I think there's some serial number's underneath the ZC...It is a single cam, non v-tec for sure...But it is from JAPAN (jdm motor)..He also told me that it is a obd-1 distributor and intake manifold etc...Also, it came out of an automatic cuz the automatic flywheel thing is still on the block.. My question's are;
What is the exact model number of this engine??
Is this from a jdm 92-up civic??
How the hell do you take the automatic thing off?? (does'nt look like there's bolt's on the housing outside!??)
What's the horsepower?? 130??
I looked at the alternator and the wire's and plug look the same as my 90si hatch 0bd-0??? Can I use this newer alternator in my 90??
aNYHELP WOULD BE APPRECIATED...tHANX
Old Mar 16, 2007 | 03:05 AM
gibsanez's Avatar
Default Re: What motor do I have?? Please help! Sorry, no pix... (EF_PINOYGUY)
That auto plate comes off with all those bolts that hold it to the crank, but by the way, DO NOT use those bolts to hold a flywheel on, you will need actual manual flywheel bolts.
Old Mar 16, 2007 | 10:05 AM
Thanx, but I see no bolt's at all if im looking at the auto plate,just a smkall hole in the middle..Is it behind it???
Old Mar 16, 2007 | 02:40 PM
JLefevers's Avatar
Default Re: (EF_PINOYGUY)
yes damn look before u post up some stupid question if you don't even know how to take a TORQUE CONVERTER off please tell me that you are not trying to do this swap yourself????
Old Mar 16, 2007 | 04:59 PM
1.6civicturbo's Avatar
Default Re: (JLefevers)
they guy just needs help there is no need to get mouthy. im preaty sure u asked some stupid questions before. but anyway the zc is the same as the d16a6 in japan.
Old Mar 16, 2007 | 05:22 PM
JLefevers's Avatar
Default Re: (1.6civicturbo)
^^^^ true but there are so many threads in the archive that has been over this topic thats all i am tring to say
Old Mar 17, 2007 | 01:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JLefevers &raquo;</TD></TR><TR><TD CLASS="quote">yes damn look before u post up some stupid question if you don't even know how to take a TORQUE CONVERTER off please tell me that you are not trying to do this swap yourself???? </TD></TR></TABLE>
Actually I am... To be honest I never seen a torque converter because I never owned an automatic Mouthy!...So excuse me for asking, I thought that is what forum's are for...And yes I tried to do a search and didn't find anything on removal of torque converter!..It was tricky but i finally figured it out!..I've already done rear disc conversion with e-brakes and all on my Ef civic and B16 swap by myself and a number of other thing's...So yes, Im pretty capable but still learning some stuff like a dam torque converter!... Thank god for the internet...
Old Mar 17, 2007 | 01:40 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6civicturbo &raquo;</TD></TR><TR><TD CLASS="quote">they guy just needs help there is no need to get mouthy. im preaty sure u asked some stupid questions before. but anyway the zc is the same as the d16a6 in japan.</TD></TR></TABLE>
Hey thanx..Your right..They finally told me it was same as d16a6 here in u.s.? Is the horsepower around 120-130?? even if it's a jdm zc?? thanx..D-series.org's Head identification is too busy..I don't see the Hp rating for d16a6?...Think im just tired..
Old Mar 17, 2007 | 01:48 AM
Maldito X's Avatar
d16a6 has 106 hp
R1de0rd1e
Jul 31, 2018 05:24 PM
EF_PINOYGUY
Mar 17, 2007 01:26 AM
bracket 4 life
Oct 25, 2006 01:47 PM
9WON4
Apr 25, 2005 11:39 AM
EF9Si-T
19
Nov 26, 2004 10:27 PM
