Need help with new tires
Old Mar 15, 2007 | 10:44 PM
sony224422's Avatar
Default Need help with new tires
I just got some rims, there 17x7. My accord is stock height, so im looking at putting 215/45-17's on the rim. Will i run into any problems? I looked at the tire size calculator and it said it will only be 60.4 mph when im at 60. so thats perfectly fine, but i don't want to mess anything else up. I could get the rims with 205/40-17's for 100$ more ( kuhmo's) but there too small for my car.
Also, where can i get tires for like $150-$200 for summer only? I looked at tire rack but im not sure if there the cheapest.
Edit: Tire rack recommends 205/45-17's. Wouldn't those be too small?
Old Mar 16, 2007 | 06:48 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Need help with new tires (sony224422)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 &raquo;</TD></TR><TR><TD CLASS="quote">Edit: Tire rack recommends 205/45-17's. Wouldn't those be too small?</TD></TR></TABLE>
You have a 94-97 Accord right? If so, that size is almost the exact OD as the stock tire. And a 205 width tire is fine for a 7" wide rim. They are fine to go with.
Old Mar 16, 2007 | 02:36 PM
sony224422's Avatar
Default Re: Need help with new tires (TouringAccord)
thanks man, i'll look into getting those then.
Old Mar 17, 2007 | 07:05 AM
H-T Order of Merit
yep, no problem
Old Mar 18, 2007 | 07:29 PM
sony224422's Avatar
what about the 215? jw
Old Mar 18, 2007 | 08:37 PM
Grandhustleman86's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 &raquo;</TD></TR><TR><TD CLASS="quote">what about the 215? jw</TD></TR></TABLE>
Went outside to check my tires size out(and damn is it cold)....my tire size is a 205/40/r17....and in my opinion the 205/45/r17 will fill the wheelwells better....the 40's just look funny without a 2"-3" drop....but hey its your opinion that counts....
FYI....I own a 91' DX 4dr
Old Mar 18, 2007 | 09:08 PM
sony224422's Avatar
Default Re: Need help with new tires (Grandhustleman86)
hmm thanks. yeah im def gunna get 45's, since i don't have a drop
Old Mar 19, 2007 | 03:55 AM
H-T Order of Merit
do not try to fill or judge fender gap with the side wall of the tire.
GrandHustleman86:
part the reason your 205/40/17 may look weird is because they are on the small side compared to your stock tire diameter, you should have went with a 205/45/17 to keep the OD of the tire as close as possible to stock.
sony224422:
the 215/45/17 should be fine. You shouldn't rub unless you have some weird offset in the rims you are buying. They'll just be a little oversize but nothing bad or that you should even notice.
Old Mar 19, 2007 | 06:01 AM
Twixle's Avatar
ate my pixel
I would definitely buy at a local tire shop rather than off tirerack, I don't know about the price comparison, it's probably comprable after shipping. But if you buy from a good local shop you can get free flat repair, roadside assistance, etc.
timpol
Aug 28, 2007 06:47 AM
JDM_Acccord
Jul 26, 2007 10:09 PM
dt4life
May 4, 2006 01:38 PM
RedLinin247
Jun 24, 2003 04:09 PM
dclub01
May 24, 2003 07:45 PM
