electrical noises!!! bad relays?
Old Mar 15, 2007 | 09:23 PM
garageEF's Avatar
Default electrical noises!!! bad relays?
heres the situation: my car has been sitting for a while and when i plugged in an ecu and tried to start it.... the tach jumps to 4k when the key is in "on" position and the door/keys buzzer goes off and sounds really weak/distorted. both ecu's i have show solid red led. when i try to turn it over there is a few buzzing/electrical noises coming from the engine compartment, under the dash, and maybe a few more places and the tach drops to 0. could these be bad relays? like the starter relay? what about the tach? thats a weird problem.
Old Mar 16, 2007 | 06:02 AM
Andy R's Avatar
Default Re: electrical noises!!! bad relays? (garageEF)
It almost sounds like your harness has been rewired and when plugging in the ecu, its not getting the corect signal connections. What is the history of the car? converted for pr3 ecu for b16a? I dont think a bad relay would give you these symptoms.
Old Mar 16, 2007 | 11:30 AM
garageEF's Avatar
Default Re: electrical noises!!! bad relays? (Andy R)
its 91 std converted to mpfi with 88 crx si parts. ive heard that 88 has differences from 91. its pretty wet where i live, could that be a factor?
Old Mar 16, 2007 | 11:40 AM
Perfectionist's Avatar
How's the battery?
Old Mar 16, 2007 | 12:31 PM
garageEF's Avatar
Default Re: electrical noises!!! bad relays? (Perfectionist)
the battery might be part of the problem. i just had the car connected straight to a battery charger to check codes, but when it was acting weird i tried to start it. do you think all the problems would go away if i tried with a battery?
Old Mar 16, 2007 | 02:40 PM
garageEF's Avatar
TTT
ninty7hatch
Dec 10, 2009 08:42 AM
eaterofsmoke
Oct 7, 2009 07:27 AM
92_civicsiR
Dec 10, 2004 12:00 PM
BudG2
Oct 12, 2004 06:22 AM
darwin22
Jan 16, 2003 04:12 AM
