95 civic lx, bad idle, exhaust moke from radiator car, white smoke, etc?????? headgasket or cracked
Old Mar 15, 2007 | 05:11 PM
turboex's Avatar
Default 95 civic lx, bad idle, exhaust moke from radiator car, white smoke, etc?????? headgasket or cracked
Ok i have a 95 civic lx the thing started to eat a bit of coolant over the last month, then started to idle real bad. I could remove the cyl-1 plug and it would be wet and would real make no power diffrence as it was running on 3 cyl's. I get a bit of white smoke for the exhaust and white exhaust smelling smoke from the radiator fill. Im guessing the head gasket is leaking but whats the chances its a cracked head? Are cracked heads comon on civics or is the money more on the hg? thanks
Old Mar 15, 2007 | 07:57 PM
94 Civic's Avatar
Default Re: 95 civic lx, bad idle, exhaust moke from radiator car, white smoke, etc?????? headgasket or crac
hmm it should be the gaskets . The same thing happen to my civic .
Old Mar 16, 2007 | 03:16 AM
turboex's Avatar
Did yous do the bad idle stuff? Mine honestly feels like it still has great power once you get above idle speeds. thanks
Old Mar 16, 2007 | 10:13 PM
94 Civic's Avatar
yes it did
Jeanious
Mar 4, 2015 02:54 AM
tony7626
Mar 27, 2009 10:48 PM
5Point7Liter
Sep 22, 2008 04:46 PM
92b16si
Jan 28, 2005 06:04 PM
