Dizzy Question....
Old Mar 15, 2007 | 04:54 PM
C_R_X_V_T_E_C's Avatar
Default Dizzy Question....
i had a D15b in my car im swaping in a Y5 bottom with a Y8 head....the dizzy is from a ZC and it has a 2 wire round plug and a 5 wire square plug....the dizzy from my d15 has the 2 wire round plug, but the 5 wire plug is different... i wanted to know if i can use the connector from the d15 dizzy and just rewire the ZC dizzy and repin the plug so it will work?
Will this work? if not can you explain what i need to do? and if this just seems like incoherent rambling, ask questions.....
Thanks,
ONE DESPRATE EFer....
Old Mar 15, 2007 | 10:29 PM
Default Re: Dizzy Question.... (C_R_X_V_T_E_C)
bump for the answers...
Old Mar 16, 2007 | 05:58 AM
Andy R's Avatar
yes, that is exactly what you need to do, repin the harness side to use the dizzy's square plug
Old Mar 16, 2007 | 10:28 AM
Default Re: Dizzy Question.... (Andy R)
thanks... but i alson need to know if i can just match the 3 wires pinned on the top of the plug and the 2 wires on the bottom of the plug with the wiring harness... this is because the colors dont match...
Also, the D15 dizzy was rewired, it has 4 wires whereas the zc dizzy has 2, the 4 wires from the D15 go in C1 & C2 of the Ecu, and i know that the guy before me did this... My question is can i depin the 4 wires and run 2 new wires so that the 2 wire plug for the zc dizzy will work? will this work? if not, any suggestions?
Modified by C_R_X_V_T_E_C at 3:53 PM 3/16/2007
Modified by C_R_X_V_T_E_C at 4:45 PM 3/16/2007
Old Mar 16, 2007 | 01:45 PM
Old Mar 17, 2007 | 10:14 AM
anyone?
Old Mar 17, 2007 | 10:55 AM
zenon8890's Avatar
is it a dohc zc or sohc zc?!
Old Mar 17, 2007 | 09:56 PM
Default Re: (zenon8890)
sohc zc...
Old Mar 18, 2007 | 02:05 AM
4thgenhtch's Avatar
Default Re: (C_R_X_V_T_E_C)
Your going to need a multipoint ECU, and dist, it has 2 round plugs, 1 with 2 wires, and 1 with 7 wires... Then match up the 5 wires that are currently in the square plug, run the extra 2 blue wires down to the ecu and tap them to c1 and c2, Search for MPFI Conversion for more info... Unless your incoherent rambling has led me to my own
Old Mar 18, 2007 | 11:19 AM
Default Re: (4thgenhtch)
it has a p28 ecu, and the wiring harness for my d15b was already converted to mpfi... and i have the dizzy from my d15 but its too big and it wont fit...
Old Mar 19, 2007 | 01:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4thgenhtch &raquo;</TD></TR><TR><TD CLASS="quote">Your going to need a multipoint ECU, and dist, it has 2 round plugs, 1 with 2 wires, and 1 with 7 wires... Then match up the 5 wires that are currently in the square plug, run the extra 2 blue wires down to the ecu and tap them to c1 and c2, Search for MPFI Conversion for more info... Unless your incoherent rambling has led me to my own </TD></TR></TABLE>
C1 & C2 are split into a 4 socket plug.... they are split into B10(White wire with red stripe) & B12(Black)....
Question 1: Do B10 & B12 go into the 2 wire plug on the dizzy????, the dizzy has a Blk & Yellow and a Blue...
Question 2: Do the colors for the wires that i have to hook up from the dizzy match the wires on the wiring harness? or can someone tell me what colors i would use????
Question 3: <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4thgenhtch &raquo;</TD></TR><TR><TD CLASS="quote"> run the extra 2 blue wires down to the ecu and tap them to c1 and c2 </TD></TR></TABLE> which blue wire goes into C1 and which to C2...
Old Mar 19, 2007 | 11:46 PM
bumpidy, bump bump...
Old Mar 20, 2007 | 01:06 PM
bumpity, bump bump.... make my honda go....
maddix
Aug 25, 2011 11:05 PM
Tippyman
Apr 11, 2006 11:21 AM
Civic138
Apr 4, 2005 03:56 PM
skrappy
Dec 27, 2003 12:57 PM
ScottEK
Sep 26, 2002 11:50 AM
