Pics of my All-motor Setup!!!
Old Mar 15, 2007 | 04:21 PM
dhdatnigga's Avatar
Default Pics of my All-motor Setup!!!
Old Mar 15, 2007 | 04:22 PM
Combustion Contraption's Avatar
Tech?
Old Mar 15, 2007 | 04:31 PM
dhdatnigga's Avatar
Default Re: (Combustion Contraption)
GSR block with 85.5 bore with LS crank
14:2:1 Compression pistons
supertech valves springs and retainers
skunk 2 pro 3 cams
twm 50m itbs
precision 440 injectors
Modified by dhdat***** at 1:16 PM 3/16/2007
Old Mar 15, 2007 | 04:39 PM
What header is that?
Old Mar 15, 2007 | 04:43 PM
Professor15's Avatar
Looks like an RMF peice if im not mistaking it for something else. Looks like the little tag thingy is missing. Looks like a damn nice build, theres going to be alot of smack talking on b20 when thats done lol.
Old Mar 15, 2007 | 04:44 PM
Youre going to need to take care of that to keep it in one peice.
Old Mar 15, 2007 | 04:50 PM
b18avtec(A!!M0TOR)'s Avatar
man thats a nice build
Old Mar 15, 2007 | 04:52 PM
dhdatnigga's Avatar
Yeah its an RMF header.
Old Mar 15, 2007 | 04:53 PM
dhdatnigga's Avatar
Default Re: (b18avtec(A!!M0TOR))
Thanks!!
Old Mar 15, 2007 | 04:58 PM
Aquafina's Avatar
440's?
Old Mar 15, 2007 | 05:06 PM
alterdcreations's Avatar
Default Re: (Aquafina)
what gas are you running.?
high octane out their in New Jersey
Old Mar 15, 2007 | 05:12 PM
dhdatnigga's Avatar
Default Re: (alterdcreations)
110 octane! Yeah we got a couple of shops dat sell high octane gas!
Old Mar 15, 2007 | 07:29 PM
EatSleepJDM's Avatar
Default Re: (dhdat*****)
nice build, but are there cracks or anything around that plug on the back of the block, the broken area on the right
Old Mar 15, 2007 | 07:34 PM
Spoonie09's Avatar
Default Re: (EatSleepJDM)
That engine is NICEEE
Old Mar 15, 2007 | 07:43 PM
j spec's Avatar
Default Re: (Spoonie09)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EatSleepJDM &raquo;</TD></TR><TR><TD CLASS="quote">nice build, but are there cracks or anything around that plug on the back of the block, the broken area on the right</TD></TR></TABLE>
looks cracked. but doesn't matter. looks like he plugged the hole for the factory pcv black box and will be running a breather system using two large an fittings in place of the factory block plugs.
Very nice way of venting PCV
Header looks like RMF shortdrag with step
excellent 2.0 header
Old Mar 15, 2007 | 08:01 PM
ekslax's Avatar
71.172.180.139
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dhdat***** &raquo;</TD></TR><TR><TD CLASS="quote">GSR block with 85.5 bore with LS crank
14:2 Compression pistons
skunk 2 pro 3 cams
twm 50m itbs
14:2??
so whats that 7:1?
Im sure you meant 14.2:1, i hope.
Old Mar 15, 2007 | 10:18 PM
94allmotor's Avatar
damn 14.2.1. is crazy i thought i was overdoing it with 12.5.1. i like the ITBS bro
Old Mar 15, 2007 | 10:22 PM
BEAVERTOOTH's Avatar
Default Re: (94allmotor)
Thats die hard to build a motor in your bedroom.
Old Mar 15, 2007 | 10:27 PM
b16nonoy's Avatar
Default Re: Pics of my All-motor Setup!!! (dhdat*****)
nice build......I wish I was matrix..then I can upload myself on how to tune my motor..and do it myself...!!..or wish I had a tree that grew money..
word itz chris's Avatar
WOW.
I want to know what it puts down. I love the header, what kind is it?
Old Mar 16, 2007 | 03:18 AM
ALLphilthyDC2's Avatar
Default Re: (word itz chris)
looks good! especially with the RMF
Old Mar 16, 2007 | 04:52 AM
94GSRCivic's Avatar
Default Re: (ALLphilthyDC2)
I dont mean to thread jack but where do you get your 110 octane from? The only place I know of that MIGHT have it is 1320 Performance in Linden.
BGWarren's Avatar
dont like the pistons. bad flame travel w/ those
but i dont know what yourbuilding it for. but looks nice none the less
Old Mar 16, 2007 | 04:55 AM
D-Rob's Avatar
Did you build the motor yourself?
Those Pro3's are BIG.
I assume you clayed them, and degree'd them in properly?
Also, on your ITB's, how come there's no hole at the end on the timing belt side for MAP sensor? How old are the ITB's?
Just curious.
Good luck!
Looks good!
- Derek
Old Mar 16, 2007 | 05:52 AM
goforbroke's Avatar
MEAT PATTY
Default Re: (D-Rob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob &raquo;</TD></TR><TR><TD CLASS="quote">
I wondering how they are going to perform on this motor....? I know you need A LOT of motor for them to perform very well. With a lot of compression, displacement, air, and etc......
I'm staying tuned for the dyno.
