Do the skunk2 full coilovers allow you to adjust your cars height
do these allow you to lower your car whenever you want:
http://www.skunk2.com/Merchant...de=FC
how much of a drop can i go....like are they adjustable... ? something like 0-4 inch?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nongan »</TD></TR><TR><TD CLASS="quote">unless you want your car to scrape the ground on a flat surface, they should work great.</TD></TR></TABLE>
no joke mine go way lower then i'd ever need
I have had these same coilovers on my EG and they can lower the car about 0"- 4". However I would recomend changing the springs out for about 200-300lbs. less spring rate if your car is a daily driver. Thats what I did and it made it a lot more street worthy.
Remember that the lower the car is... the less travel you have and the more chance there is that the shock will bottom out and damage the valving.
Mikes2000civicsi
19
Dec 13, 2006 01:18 PM
