What plugs do i use for the JDM Cluster ??
Old May 23, 2002 | 10:34 AM
FUP23's Avatar
New User
Default What plugs do i use for the JDM Cluster ??
???? I have no idea what plugs to use. Thanks!
Old May 23, 2002 | 10:39 AM
SuperCivic's Avatar
Default Re: What plugs do i use for the JDM Cluster ?? (Devin17)
i used the plugs that came with the cluster, then repinned. did you get the four plugs with your cluster, or can you?
Old May 23, 2002 | 10:44 AM
FUP23's Avatar
New User
Default Re: What plugs do i use for the JDM Cluster ?? (SuperCivic)
No I didnt get the plugs. So now what do I do ?
Old May 23, 2002 | 10:47 AM
SuperCivic's Avatar
hmm..i dunno..the two you have on your current cluster are 8 and 12 pin plugs. the jdm one uses a 6, 8, and 10. so the 8 is covered..anybody know what clusters use a 6 and 10 pin plug? teg maybe? not sure about the green plug either
[Modified by SuperCivic, 3:09 PM 5/23/2002]
Old May 23, 2002 | 11:03 AM
JohnBlaze's Avatar
8 pin=in your car already
6 pin=90-91 integra
10 pin=85-87 crx
junkyard time
Old May 23, 2002 | 11:09 AM
SuperCivic's Avatar
Default Re: What plugs do i use for the JDM Cluster ?? (JohnBlaze)
awesome..good info
Old May 23, 2002 | 12:16 PM
FUP23's Avatar
New User
heres the problem, none of my plugs fit in this clutser ? You say the 8 should ? I cant get any to
Old May 23, 2002 | 08:32 PM
Lamchop0000's Avatar
modify the harness?
Old May 24, 2002 | 05:03 AM
SuperCivic's Avatar
dude..it's NOT plug and play..repinning is required.
dc2dragster
Feb 3, 2005 05:26 PM
Mike17
Jan 21, 2005 05:51 AM
ThefirstPACT
Mar 16, 2004 07:50 PM
4g4me
Mar 7, 2002 03:48 PM
