CRX not holding idle, then dying. HELP PLEASE.
Old Mar 15, 2007 | 02:35 PM
jdmeg6hatchy's Avatar
Default CRX not holding idle, then dying. HELP PLEASE.
I recently helped a friend put a 1992 civic dx engine into his 1988 crx dx. we swaped over to mpfi and used a crx si ecu and distributor. The car starts up and runs fine, however when you let off of the throttle the car cuts off. Does anyone know what might be causing this?? I also was wondering if we needed to swap over the map sensor or if the stock crx dx one would work?? Thanks for any help.
Old Mar 15, 2007 | 03:00 PM
Default Re: CRX not holding idle, then dying. HELP PLEASE. (jdmeg6hatchy)
anyone have any ideas?
Old Mar 15, 2007 | 03:02 PM
JustAnotherRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg6hatchy &raquo;</TD></TR><TR><TD CLASS="quote">I recently helped a friend put a 1992 civic dx engine into his 1988 crx dx. we swaped over to mpfi and used a crx si ecu and distributor. The car starts up and runs fine, however when you let off of the throttle the car cuts off. Does anyone know what might be causing this?? I also was wondering if we needed to swap over the map sensor or if the stock crx dx one would work?? Thanks for any help.</TD></TR></TABLE>
Ever heard of tuning?
Maybe air to fuel ratios?
Stock would work depending upon OBD#
Old Mar 15, 2007 | 03:33 PM
Default Re: CRX not holding idle, then dying. HELP PLEASE. (JustAnotherRex)
obd#?? were runing a crx si ecu and distributor...its obd0.
Old Mar 15, 2007 | 04:35 PM
so i can keep my stock map sensor?
Old Mar 15, 2007 | 07:36 PM
4DRmafia's Avatar
this is ron, anyway i starting to think u have to run a obd1 ecu instead? or get a better map snesor or the vaccum line is not right ? maybe i can come over and take a look at it
Old Mar 15, 2007 | 08:11 PM
Default Re: (SkipMic2006)
yeah dude thatd be great man!!!
Old Mar 16, 2007 | 01:18 PM
Default Re: (jdmeg6hatchy)
anyone else know?
Bobeasy
Jun 5, 2011 06:16 PM
ineedacrx
Nov 14, 2005 12:14 PM
Tyson
13
Oct 28, 2004 03:04 PM
celo
Dec 16, 2003 04:02 AM
AGPSuperstar
76
Apr 12, 2003 08:58 AM
