96 accord with H22a
Old Mar 15, 2007 | 02:13 PM
flatline911's Avatar
Default 96 accord with H22a
Lately every so often I notice my Tach on is starting to jump around all over then it will correct itself. Today on the way home from work it started doing it while I was on the interstate so while it was jumping I hit the gas a bit and it bogged down like a miss. When I look at my Apexi vafc the rpms look fine. any ideas would be greatly appreciated.
Old Mar 15, 2007 | 05:25 PM
phase7's Avatar
Default Re: 96 accord with H22a (flatline911)
I had the same problem in a hatch i had, it was just the plug behind all the gauges.
Old Mar 15, 2007 | 09:48 PM
4drH22Accord's Avatar
Default Re: 96 accord with H22a (phase7)
Sounds like you have a bad ground some where. Check all your wiring
duceducecord
May 14, 2007 03:35 PM
flatline911
May 3, 2007 04:37 PM
johann
Feb 26, 2003 05:24 PM
