Well my car won't start
Old Mar 15, 2007 | 01:45 PM
EJ ITO's Avatar
Default Well my car won't start
It turns over just fine but it doesn't start. I checked all the fuses and checked to see if I was getting spark to each cylinder and I do but it doesn't start. I checked to see if the timing belt was broken but it isn't and it is off timing by just a few teeths. SO DOES ANYONE HAVE ANY SUGGESTIONS? PLEASE HELP!
Old Mar 15, 2007 | 02:29 PM
EJ ITO's Avatar
anyone?
Old Mar 15, 2007 | 02:58 PM
19992civichatch's Avatar
its off by about how many theeth?
Old Mar 15, 2007 | 03:17 PM
ek4h's Avatar
Default Re: Well my car won't start (EJ ITO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ ITO &raquo;</TD></TR><TR><TD CLASS="quote"> it is off timing by just a few teeths</TD></TR></TABLE>
that could be ur problem
Old Mar 15, 2007 | 04:18 PM
EJ ITO's Avatar
about 4-6 yeah that's what I was thinking the problem would be but ill put it on correct timing tommorow and hopefully not be on here saying that my car doesn't start
Old Mar 16, 2007 | 05:45 AM
EJ ITO's Avatar
i'm about to start but does anyone have anymore suggestions
Old Mar 16, 2007 | 05:52 AM
mikeycivic's Avatar
Default Re: (EJ ITO)
is it getting fuel ?
Old Mar 16, 2007 | 05:54 AM
92redhatch's Avatar
fix the timing. Change the plugs
Old Mar 16, 2007 | 06:10 AM
EJ ITO's Avatar
yeah it's getting fuel and perfect spark
Old Mar 16, 2007 | 07:37 AM
mikeycivic's Avatar
then def. get timing fixed
Old Mar 16, 2007 | 09:49 AM
JDMKid71's Avatar
Default Re: (mikeycivic)
hopw it wasnt off my too many teeth and bend the valves...
Old Mar 16, 2007 | 10:08 AM
ALL5tar's Avatar
Ive got a simular problem, my car wont start like now and then...i just had my timming done again and its running real good. cept last nite i parked it for like? maybe 3 hours and it wouldnt start, it fires. and almost turns over? i have no idea, what else it could be? fuses? which ones to check??? under the hood and in the dash?..i can hear my fuel pump...so its not that..
Old Mar 16, 2007 | 10:50 AM
ARMED's Avatar
do you guys have an aftermarket alarm????
Old Mar 16, 2007 | 10:51 AM
ARMED's Avatar
is this a new swap?? did it just stop working???
Old Mar 16, 2007 | 10:59 AM
ALL5tar's Avatar
Default Re: Well my car won't start (ARMED)
no alarm, i put a new head on. mini me..no wired v tec though yet..
Old Mar 16, 2007 | 11:15 AM
EJ ITO's Avatar
no no alarm and no new swap it's the stock motor d16z6
Old Mar 16, 2007 | 11:17 AM
ARMED's Avatar
coil??? ECU???
Old Mar 16, 2007 | 11:19 AM
EJ ITO's Avatar
already tested that ima put it in timing tommorow, I was supposed to today but it's raining outside
Old Mar 16, 2007 | 11:22 AM
ARMED's Avatar
mm...thinkin
Old Mar 16, 2007 | 11:26 AM
ALL5tar's Avatar
well D15. with sohc head..no vtec wired yet. with the d16 ecu, new plugs wires cap rotor alt. batery..timmings done,..runs good when it starts. it will start fine, the somtimes it just wants to turn over, but wont..everything seem like its working..i thaught maybe a fuel line? or somthing got pinched when the head went on, what are the fuses i could check? could that be?
Old Mar 17, 2007 | 04:17 PM
EJ ITO's Avatar
well the car still won't start, any suggestions? Please help
Old Mar 17, 2007 | 04:23 PM
cimo463's Avatar
U prob bent some valves when it jumped timing...if you have eliminated everything else, You mite want to start yanking that head off.
Old Mar 17, 2007 | 04:50 PM
EJ ITO's Avatar
well I thought the timing was off but it wasn't for some odd reason it was marking that it was off timing when the crank pulley was on there but when I put it on exact TDC it was marking that the timing was perfect, so it wasn't the timing, I took off the alternator and checked it but it was good, checked all the fuses and good, spark, fuel, everything good, i'm runinng out of things to try, any suggestions? Please help, oh and I did a compresion check and even that was marking good
Old Mar 17, 2007 | 06:26 PM
92redhatch's Avatar
spark plugs.
Old Mar 17, 2007 | 10:07 PM
delsolck94's Avatar
this may sound dumb, but how old is the gas? my accord sat for a few months and i had to put fresh gas in to get it to start.
