front end conversion
Old Mar 15, 2007 | 10:49 AM
JDean6pac's Avatar
Default front end conversion
hey guys i no plenty of ppl hav already asked this but i havnt been able to find out so im comin 2 good ol' honda-tech boys. i gota 98 civic and im trying 2 do a 99-00 front end conversion. i keep hearin about sum radiator support ****. do i need it to do the conversion rite? and what exactly is it?
Old Mar 15, 2007 | 10:55 AM
pythoner's Avatar
you can trim a part of the bumper so you don't have to do the core support
Old Mar 15, 2007 | 11:10 AM
joshburke's Avatar
Default Re: front end conversion (JDean6pac)
try this https://honda-tech.com/zerothread?id=790135-
Old Mar 15, 2007 | 11:11 AM
BlueIntegraBoy's Avatar
Swapping the radiator support will make a perfect fit that will look completely stock, otherwise you'll have two notches on the bumper.
Old Mar 15, 2007 | 11:14 AM
JDean6pac's Avatar
Default Re: front end conversion (BlueIntegraBoy)
ok but what does it take 2 swap the radiator support? is it difficult? could i do it myself?
Old Mar 15, 2007 | 11:21 AM
Weld it in
Old Mar 15, 2007 | 11:31 AM
JDean6pac's Avatar
das prly expensive as ***** aint it?
Old Mar 23, 2007 | 11:00 AM
JDean6pac's Avatar
any1 dun a front end conversion WITH the radiator or core support or w/e its called? how much did it cost you. jus the welding part? and yea i dunno wer the support is actualy so without gettin flamed.... can sum1 tell me wer it is?
Old Mar 23, 2007 | 11:08 AM
95ProjectEJ1's Avatar
Check it out... Someone posted this link in a thread a few days ago. It may be helpful.
http://www.jdmuniverse.com/for...rsion
Old Mar 23, 2007 | 11:09 AM
ifIexplode's Avatar
is it me or is more and more threads becoming like txt messages. tryin to decode your posts. Whats so hard about typing the entire word?
*some
*where
*just
*dont know idk
*done.
Old Mar 23, 2007 | 11:13 AM
JDean6pac's Avatar
Default Re: (ifIexplode)
ok look im just looking for answers man. not smart *** comments . so if you arent here to answer my question and help me, take your "proper english" crap else where.
Old Mar 23, 2007 | 01:36 PM
hall97civic's Avatar
Default Re: (JDean6pac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ifIexplode &raquo;</TD></TR><TR><TD CLASS="quote">is it me or is more and more threads becoming like txt messages. tryin to decode your posts. Whats so hard about typing the entire word?
.</TD></TR></TABLE>
First off I aggree with this guy. Secondly, the core/rad. support is the peice of pressed steel that you radiator mounts to and connects the left and right side of your car. If you had a welder, not hard to do as long as you tear everything off of the front end. To remove the original one, you will have to get a drill and drill out the spot welds that hold it on, then you slap the new one in its place and tack it in with the welder, then re-assemble.
later
Old Mar 23, 2007 | 01:44 PM
alacard's Avatar
The support is really not necessary. you still have all of the other bolts and you just have to cut two small slits in the bumper that is unnoticable unless you pop the hood and look for it. If you want to spend more cash and a lot more work, go for it. Otherwise do it the simple way.
EM2K20
Honda Civic (2001 - 2005)
Aug 5, 2010 04:35 PM
supe's_civic
Aug 22, 2008 03:00 PM
JDean6pac
Welding / Fabrication
Apr 12, 2007 04:52 AM
silentdeath12886
Sep 13, 2006 03:58 PM
Hatchbizzack
Apr 26, 2004 11:45 PM
