WHY IS MY CAR OVERHEATING
I HAVE A 1990 CIVIC 4 DOOR WITH A 95 V-TECH MOTOR AND THE RADIATOR HOSE DON'T HAVE ANY PRESSURE AND IT KEEPS OVER HEATING. THE ANTIFREEZ KEEPS GOING TO THE OVERFLOW BOTTLE CAN SOME ONE HELP ME WITH THIS THANKS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPORT_IMAGE »</TD></TR><TR><TD CLASS="quote">I HAVE A 1990 CIVIC 4 DOOR WITH A 95 V-TECH MOTOR AND THE RADIATOR HOSE DON'T HAVE ANY PRESSURE AND IT KEEPS OVER HEATING. THE ANTIFREEZ KEEPS GOING TO THE OVERFLOW BOTTLE CAN SOME ONE HELP ME WITH THIS THANKS </TD></TR></TABLE>
Try a new thermostat and bleed it good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist »</TD></TR><TR><TD CLASS="quote">
Try a new thermostat and bleed it good.</TD></TR></TABLE> x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPORT_IMAGE »</TD></TR><TR><TD CLASS="quote">I PUT A NEW THERMOSTAT AND A NEW RADIATOR AND ITS STILL GETTING HOT WHAT ELSE COULD IT BE</TD></TR></TABLE>
I LOVE CARPET.
I LOVE LAMP.
I LOVE CARPET.
I LOVE LAMP.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andy R »</TD></TR><TR><TD CLASS="quote">I know exactly what the problem is...this is what you need to do:
Look at the keyboard
Hit the caps lock key until the LED indicator for the caps lock turns off
</TD></TR></TABLE>jackass at least try to help him or are all you replys this ignorant...seriously though take off the CAPS...ok is your reservior in its stock location "above or below hook-up to the cap area"...I had this problem where it keep sending it back turns out I had a cracked head. But if you are losing no coolant at all "not talking about just leaking" are you sure the thermostat is installed correctly?
im gonna bet you have a leak.. my rad would push all the coolant to the over flow till it was.. well overflowing, turned out to be the rad. it had tiny holes that would leak, so small that you couldnt see it on the ground. it happenes when the fins on the rad start to break off and rip tiny holes in the lines running thru the rad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n »</TD></TR><TR><TD CLASS="quote">im gonna bet you have a leak.. my rad would push all the coolant to the over flow till it was.. well overflowing, turned out to be the rad. it had tiny holes that would leak, so small that you couldnt see it on the ground. it happenes when the fins on the rad start to break off and rip tiny holes in the lines running thru the rad. </TD></TR></TABLE> yah thats what i thought it has to be leaking, check the radiator feel around for moisture, and also if fluid is going into your block due to bad headgasket you could be losing it and not knowing...any white smoke?
im not too sure but i think any amount of coolant being burned would show up in the exhaust.
and if you have tiny holes in the rad like mine then you probably wont feel any moister because it evaporats right away .. cuz it leaks out a fine mist. im pretty positive you need a new rad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n »</TD></TR><TR><TD CLASS="quote">im not too sure but i think any amount of coolant being burned would show up in the exhaust.
and if you have tiny holes in the rad like mine then you probably wont feel any moister because it evaporats right away .. cuz it leaks out a fine mist. im pretty positive you need a new rad.</TD></TR></TABLE>
he said he has recently put in a new thermostat and radiator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPORT_IMAGE »</TD></TR><TR><TD CLASS="quote">Yeah im sure its installed correct the could it be that where the thermostat go is that whole part is not bolted on to the motor</TD></TR></TABLE>
So you have no water neck? I don't understand.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civhatch90 »</TD></TR><TR><TD CLASS="quote">
he said he has recently put in a new thermostat and radiator</TD></TR></TABLE>
oh.. reading owns me.
probably a leak somewhere then. or an ail lock?
Have you bled the system and made sure the flapper valve isn't shut? You can find it here:
Majestic Honda
Majestic Honda
