Oil filter bolt
has anyone removed the oil filter stud/bolt that the oil filter bolts onto on the F22 block? Ive heard people mention putting the H22 oil cooler on the F22 block but I don't think I've seen anyone actually say they've done it. Has anyone done this? Is the F22 oil filter bolt just threaded in? I just wanted to see if anyone has done this before I try it myself
I was under my prelude yesterday changing my oil cooler o-ring. It should be able to swap over, I did it on my old b18c I had in my civic/teg. Someone correct me if I'm wrong, but should be able to get that stud piece from the h22, the h22 oil cooler(w/ new o-rings), the h22 rear water pipe (w/ new o-rings). Should swap over, only main concern I'd have is using a h22 water pipe on a f22 (fitment).
i forgot about having to use a new waterpipe, that shouldnt be a big issue since im going to be hacking up some waterpipes because I'm putting an h22 head on the block anway, so its going to need a new waterpipe regardless
