Shopping for piston
Old Mar 15, 2007 | 03:43 AM
DA_JDM's Avatar
Default Shopping for piston
Hey guys,
Im looking for 81.5mm between 12 and 12:5 or CR...my question is: When im looking at the product listing on each of JE, wiseco and arias...i dont see a lot of choice for 12 and up of CR for the b18c5 engine...but in the b18c1 section i see a lot more...can i just pick one up from the b18c1 chart instead of the b18c5 chart???
Thanks
Old Mar 15, 2007 | 11:18 AM
DA_JDM's Avatar
Default Re: Shopping for piston (DA_JDM)
Old Mar 15, 2007 | 11:24 AM
doood's Avatar
been there done that
the cr numbers listed for a b18c1 will be slightly off if you put them in a b18c5
Old Mar 15, 2007 | 11:30 AM
98vtec's Avatar
moderator emeritus
Default Re: Shopping for piston (doood)
damn, what cam you going with that needs all that compression, LOL
Old Mar 15, 2007 | 03:32 PM
DA_JDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">the cr numbers listed for a b18c1 will be slightly off if you put them in a b18c5</TD></TR></TABLE>
What do you think the difference should be like???
Old Mar 15, 2007 | 03:33 PM
DA_JDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">damn, what cam you going with that needs all that compression, LOL</TD></TR></TABLE>
JUN III
Old Mar 15, 2007 | 03:47 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_JDM &raquo;</TD></TR><TR><TD CLASS="quote">What do you think the difference should be like???</TD></TR></TABLE>
best thing to do is take the numbers listed for compression height and dome cc and put them into a compression calculator like http://www.zealautowerks.com to give you a good idea of where it'll be.
JUN III </TD></TR></TABLE>
you dont need all that compression for jun3's
Old Mar 15, 2007 | 03:54 PM
DA_JDM's Avatar
you dont need all that compression for jun3's</TD></TR></TABLE>
I was told that more compression they see the better the Gain will be!!! They sure gonna need more then 11 or 11:5...
And for the calculator i cant never work that out...its confusing me more that its helping me
Old Mar 15, 2007 | 04:28 PM
doood's Avatar
And for the calculator i cant never work that out...its confusing me more that its helping me </TD></TR></TABLE>
s2s2's (similar to jun3's) seem to do very well in the 11:1 range.
the compression calculator is very easy to use. click on what block, crank, head, etc. you're using and when it asks for piston click custom and enter values for dome cc and compression height. that info will be available on the manufacturers website. dont forget to fill in the head milled and block decked sections if you've had that done.
Old Mar 15, 2007 | 11:26 PM
ExospeedAMcrx's Avatar
Look at the B18C1 choices and it will be slightly less, but not much. Base your choice on the B18C1 applications.
Arias offers an 81.5mm 12.7:1 compression for the C1. We've been using and selling these alot lately. Lots of people looking for unsleeved setups that are in the 12:1-13:1 compression
Old Mar 16, 2007 | 03:43 AM
DA_JDM's Avatar
Default Re: Shopping for piston (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">Look at the B18C1 choices and it will be slightly less, but not much. Base your choice on the B18C1 applications.
How much???
Old Mar 16, 2007 | 03:44 AM
DA_JDM's Avatar
the compression calculator is very easy to use. click on what block, crank, head, etc. you're using and when it asks for piston click custom and enter values for dome cc and compression height. that info will be available on the manufacturers website. dont forget to fill in the head milled and block decked sections if you've had that done.</TD></TR></TABLE>
Sorry but i wont run those cams with stock compression level...thats ridiculous
DA_JDM's Avatar
What do you guys think about the 12:1 from JE for a b18c5???
Old Mar 16, 2007 | 11:40 AM
Those calculators are a source for "getting an estimate" but I wouldnt rely on them as an actual calculator. its off and may not reflect what you are really looking for.
Old Mar 16, 2007 | 12:17 PM
DA_JDM's Avatar
Those calculators are a source for "getting an estimate" but I wouldnt rely on them as an actual calculator. its off and may not reflect what you are really looking for.</TD></TR></TABLE>
Thanks
almostboostedgsr
Jul 29, 2008 11:45 AM
thegeezerkid
May 21, 2008 11:02 AM
DA_JDM
Apr 23, 2007 03:02 PM
quis23
Feb 28, 2005 03:51 AM
fast95civic03
Aug 27, 2004 07:46 PM
