valve compressor tool
Old May 23, 2002 | 09:42 AM
garagespecial
Guest
Posts: n/a
Default valve compressor tool
where do i find the tool that holds the valves while taking out the valve springs...thanks
ceasar
Old May 23, 2002 | 10:33 AM
Redline130's Avatar
Default Re: valve compressor tool (garagespecial)
Here you go: http://www.thetoolwarehouse.net/shop/SP-91400.html
It's very similar to the Snap-on one. I have one and it works pretty good.
Old May 23, 2002 | 10:35 AM
garagespecial
Guest
Posts: n/a
Default Re: valve compressor tool (cyber13)
how does that tool hold the valves from dropping?
Old May 23, 2002 | 10:45 AM
Redline130's Avatar
You'll need to use compressed air sent down thru the sparkplug hole to keep the valves up. The only other way would be to remove the head like I had to after I dropped a keeper down an oil passage
ge_itr
Jul 14, 2006 10:25 AM
DanishR
Mar 3, 2006 12:00 AM
Rob Dizzle
Aug 26, 2004 02:59 PM
AznBlueBoy
May 12, 2004 07:39 AM
BeerMan
Jan 27, 2004 10:11 PM
