48mm turbosmart WG, who can make topmount manifold for it.
Old Mar 14, 2007 | 10:52 PM
V-SPEC 1's Avatar
Default 48mm turbosmart WG, who can make topmount manifold for it.
I'm looking for anyone that can build me as good as Full-race topmount manifold that can accomodate the 48mm Turbosmart WG. I know Full-race don't make them for this big WG. Can you please let me know who I should go to? Thank you in advance.
Old Mar 14, 2007 | 10:56 PM
Boner_Ben's Avatar
Default Re: 48mm turbosmart WG, who can make topmount manifold for it. (V-SPEC 1)
My topmount will be here this week and I am just cutting off the tial flange and welding a new flange on for my 48mm progate.
Old Mar 14, 2007 | 11:02 PM
V-SPEC 1's Avatar
Default Re: 48mm turbosmart WG, who can make topmount manifold for it. (Boner_Ben)
what size tial does it have right now? The topmount manifold is going into EG hatch w/ fiberglass front end, LS/VTEC setup. I'm currently using the Full-race ramhorn mani w/o A/C and 3" dp. if that helps. Thanks again.
Old Mar 15, 2007 | 06:57 AM
building boost's Avatar
the tial 44mm wg flange and turbosmart 48mm flange are the same size v band. if the issue is that it is too big, maybe u can try an elbow so the wastegate is parallel to the radiator support.
Old Mar 15, 2007 | 07:01 AM
JoePSI's Avatar
Default Re: (building boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by building boost &raquo;</TD></TR><TR><TD CLASS="quote">the tial 44mm wg flange and turbosmart 48mm flange are the same size v band. if the issue is that it is too big, maybe u can try an elbow so the wastegate is parallel to the radiator support.</TD></TR></TABLE>
I thought they were the same. Its the same with that new synapse wg coming out. their 40mm fits a tial 38mm and so on.
Old Mar 15, 2007 | 08:16 PM
Boner_Ben's Avatar
Thats odd I have a tial 44mm flange and a turbosmart 48mm wastegate right in front of me and the tial flange is definitly too small.
Old Mar 15, 2007 | 11:08 PM
V-SPEC 1's Avatar
Default Re: (Boner_Ben)
That's what I thought. The Turbosmart 48mm should be bigger than the Tial 44mm. I'll go get my 48mm and I guess i'll measure the ID of the flange and see how big it is. I don't have the Tial 44mm, if somebody have them, please measure the ID of the flange so we can compare the 2. Thanks.
Old Mar 15, 2007 | 11:16 PM
V-SPEC 1's Avatar
OK, the ID of the TS 48mm is exactly 45mm. I measured that from the mating flange of the gate. Now, if I measure it from the gate itself where the valve is, it's approximately 44.65mm.
Old Mar 16, 2007 | 02:42 AM
DaveF's Avatar
the turbosmart wg shares the same flange as the JGS wg.
https://honda-tech.com/zerothread?id=1911259
SI_frankenstein
Jul 16, 2011 03:45 PM
TwoKSiR
Jul 25, 2009 08:38 AM
Mr. Vapor
Welding / Fabrication
12
Feb 10, 2006 02:36 PM
evoeone
Mar 6, 2003 05:40 PM
