Z6 Swap.....Need help!!!!!
Old Mar 14, 2007 | 08:18 PM
Blk_EJ1's Avatar
Default Z6 Swap.....Need help!!!!!
I'am having a probllem with my Z6 swap in to my 95 ex coupe. I turn the key engine turns but wont start. First two times turning the key it popped but doesn't do it anymore. so I took the t-belt off and TDC the cam and crank. put the belt back on and tighten the tensioner get it all back together to start, when I turn the key nothing the same thing. except know I'm throwing cel # 10 I think. I'm not sure what to do, motor is all stock with replaced gaskets and arp head bolts, my old motor just had high milage. any help or Ideas........
here is a vid of the CEL..... is it Right????
Modified by Blk_EJ1 at 9:36 PM 3/14/2007
Old Mar 14, 2007 | 09:01 PM
92ehatch's Avatar
Default Re: Z6 Swap.....Need help!!!!! (Blk_EJ1)
yup thats a code 10 IAT - Intake Air Temperature sensor.
do you hear your fuel pump priming? when you turn the key on? if not it could be the main relay.
check all fuses?
all grounds? especially the damned transmission ground..
i forgot that ground my first time around, and the car wouldnt do anything
Old Mar 14, 2007 | 10:45 PM
Blk_EJ1's Avatar
Default Re: Z6 Swap.....Need help!!!!! (92ehatch)
yea I hear the fuel pump prime......I checked all the fuses and there good. I checked the grounds and those are also fine. It turns over like it's going to start but not catching......I'll try and get a vid of it.....about that IAT sensor, do I replace that or what??? and where is it located???? I know that's a noob Question but this is Honda-Tech...........any more help or advice would be great, I'm not seeing why this wont start and I'm thinking it's electrical...........
Old Mar 15, 2007 | 08:14 AM
92ehatch's Avatar
its a white sensor on the intake manifold. i dunno exactly where its at on the stock manifold
Old Mar 15, 2007 | 01:27 PM
Blk_EJ1's Avatar
okay gotcha.........I would post a vid of me tryin to start the car but my digi doesn't have sound.........
Modified by Blk_EJ1 at 4:22 PM 3/15/2007
Sonny04627
Engine Management and Tuning
Jul 7, 2014 09:37 AM
fog raw
15
Nov 8, 2011 09:58 AM
RDAYA0
Apr 10, 2008 12:55 PM
Terry36
Jul 13, 2007 02:14 PM
LilCivic04
Mar 7, 2005 08:27 PM
