Need help with plastigauge results...
Old Mar 14, 2007 | 07:21 PM
Boilermaker1's Avatar
Default Need help with plastigauge results...
In the process of building a motor, my first one, need a little help here, trying to make sure I can get the bearings sized right, just wondering if these results seem ok. I used the original bearings, not new ones, just to see if I can get a ballpark here.
The specs in the manual are
#1 and 5 - .0007-.0014"
2,3,4 - .0009-.0017"
This is what I get off the used bearings and their codes as I took them off the block and crank codes.
#1 - Pink - .0015
#2 - Green - .002
#3 - Yellow - .002-.0025 (somewhere between)
#4 - Green - .002
#5 - Yellow - .0015-.002 (somewhere between)
Honda's numbers are a bit more precise than I can find plastigauge for, so I used the green thread (.001-.003").
These bearings have ~70K on them. If I order the same colors as new should I be alright for a starting point? They seem a little loose, I almost wonder if I screwed up.
Modified by Boilermaker1 at 11:47 PM 3/14/2007
Old Mar 15, 2007 | 05:36 AM
Anyone?
Old Mar 15, 2007 | 08:37 AM
Finland's Avatar
I'm sure a few ten thou wore off the bearings in 70K miles.
I'd order a new set of the factory colors and re-check.
Old Mar 19, 2007 | 02:49 PM
Tomdata's Avatar
Default Re: Need help with plastigauge results... (Boilermaker1)
as long as it spins when the caps and rods are tight, and there are bearings in there. its cool..
god.loves.ugly
10
Dec 15, 2007 01:59 AM
XkjeldorX
May 7, 2007 04:31 PM
willywong
Aug 19, 2006 11:51 PM
aldong
Apr 27, 2005 10:29 PM
SkRiBLaH
Jul 28, 2004 10:24 AM
