ebay special taillights
Old Mar 14, 2007 | 06:09 PM
liljestrand's Avatar
Default ebay special taillights
yeah i know im gonna get crap for this but i bought these
http://cgi.ebay.com/ebaymotors...d=1,1
now the only problem is that there is no light when brakes are pushed,
the outer parts come on when lights are turned on and for the turn signals,
but nothing on the lights on the trunk lid itself,
now they only had one plug in and obviously its not the right one.....so can i splice the wires somehow to make these work
any help is greatly appreciated
Old Mar 14, 2007 | 06:13 PM
slim689's Avatar
Default Re: ebay special taillights (liljestrand)
lol
Old Mar 14, 2007 | 06:20 PM
Default Re: ebay special taillights (slim689)
see i knew it would happen....anways after thinking bout it i may be able to use one of the other plugs.....
there are two on the stock light....does anyone which one is what
Old Mar 14, 2007 | 06:30 PM
5G_Vtec's Avatar
To be honest, I like those. Who gives a crap about what other people think. It's your car, your money. Do what you want with it.
I just ordered these:
And I'm sure I'll get crap for them also because they're somewhat of an "altezza" style, but so be it. I don't care what people think, as long as I like them I'm fine.
But back to your question, have you tried changing the bulbs? And, is it just one of the brake lights or both?
Old Mar 14, 2007 | 06:31 PM
skingfreak's Avatar
if you have some intution, and a little bit of knowlege, and a slight will power to get it done, it will work just sit down, look at your stock tailights, than splice, and re-wire your new ones to imitate your stock ones
sorry if that sounds like im being a dick, not trying
Old Mar 14, 2007 | 06:35 PM
Default Re: ebay special taillights (skingfreak)
no its cool...and greatly appreciated....its the two lights that are on the trunk lid itself (91 honda accord) the stock lights have two bulbs and another plug in thing...whereas these only have one bulb slot...and neither of them work
Old Mar 14, 2007 | 06:39 PM
5G_Vtec's Avatar
Hmm, that's odd. When you order tail lights for your year car, they should have the same amount of slots for the bulbs. You said the bulb plugs aren't fitting into your new tail light slots?
Old Mar 14, 2007 | 07:21 PM
skingfreak's Avatar
do the lights fit your car properly? before i go cutting up the wiring i would talk to the seller (even tho you will most likely be chasing your tail)
if your determined to get it wired up in the near future, i would just splice into the wire for the bulbs that do work (since im sure that all the stock harness did)
but just so were all on the same page, you say have lights that are insalled on the trunk lid itself and there not working correct? but the other lights that you did install do work?
Old Mar 14, 2007 | 07:27 PM
well you know how theres 4 sections....two on the fender area, and then the two on the trunk lid...
i have lights in the fender ones....those work when i turn on my lights and they flash for turn signals...
the actual brake lights( the ones on the trunk lid) are the ones not working right
they do fit....well the stock has two bulbs whereas the new ones only have one...im gonna fiddle with it when its light again tomorrow....but now that i think about it i may have been using the reverse light bulbs
Old Mar 14, 2007 | 09:44 PM
hometheaterman's Avatar
Maybe check the bulbs. I know when I replaced my tail lights it blew out a bunch of bulbs at first. Not sure why but I haven't had a problem since changing them.
Old Mar 15, 2007 | 05:37 PM
Default Re: ebay special taillights (hometheaterman)
ok so after some tinkering in the daylight i came to the conclusion that
1. the pieces on the trunk lid are pretty much decorative except that they house the reverse lights only.
2. I managed to get my brake lights to work on the outer parts....
it was this little green box with a circuit board inside...which i assume is to control the brake lights...so i had to jack those off of the stock lights and blam now they work
thanks for all the input guys
Old Mar 15, 2007 | 06:38 PM
99hondaaccord's Avatar
I have the same problem. I kinda just hope cops dont drive behind me cuz Im not TOO worried about it but do you think you could go into more detail about how you fixed this problem???
Old Mar 17, 2007 | 02:04 PM
Default Re: ebay special taillights (99hondaaccord)
ok this is how they look on there, and to get them to work there is this:
its a little green circuit board that is attached to the stock lights...just unscrew it and plug it in and all the lights should work
and yes i know my car is dirty, and yes that rust spot is going to get taken care of
Old Mar 17, 2007 | 02:14 PM
professorman's Avatar
I'm not one to bash someone for what they like....but not the biggest fan of how the lights look in the pictures. On ebay, they looked great. Did you order a different one?
Old Mar 17, 2007 | 03:54 PM
Default Re: ebay special taillights (profroopchan)
no i ordered the ones pictured...it might just be the picture...i took it with a camera phone...but they look great in person
Old Mar 17, 2007 | 04:52 PM
Grandhustleman86's Avatar
dont mind them too much....kinda look good....Im a huge fan of the 90-91 stock tails tho....but yeah i bought some ebay tails for my 90' Civic Hb and like 2 tail light bulbs wernt needed to operate the Euro's....so i just pulled bulbs out of them and tucked them where they couldnt be seen....
Old Mar 17, 2007 | 05:18 PM
5G_Vtec's Avatar
I like them no matter what anyone else says.
I'll post some pictures of the new tail lights here once I get them and install them.
Old Mar 17, 2007 | 10:11 PM
hapexamendios 2.0's Avatar
R.I.P.
Default Re: ebay special taillights (Grandhustleman86)
wow, and i was almost sure the accord forum was where all the ricers were.. now im positive
Old Mar 18, 2007 | 05:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liljestrand &raquo;</TD></TR><TR><TD CLASS="quote">no i ordered the ones pictured...it might just be the picture...i took it with a camera phone...but they look great in person</TD></TR></TABLE>
Yea, Camera phones take crappy pictures sometimes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hapexamendios 1 &raquo;</TD></TR><TR><TD CLASS="quote">wow, and i was almost sure the accord forum was where all the ricers were.. now im positive </TD></TR></TABLE>
Yea, and everyone on H-T takes a slow car and try to make it go fast...however, you are not supposed to drive faster than the speed limit which is crazily low in most places. How about leaving the engine slow and leaving the engine reliable?
Accord forum is for "technical" discussion and help with issues. This guy had one of those so called 'technical' issues, because he could not wire up his lights. When others do a engine swap and cant wire up the VTEC or something, people here help them.
After he got it fixed, we wanted to see the finished product, because we spent our time helping. I am sure most people want to know the result of the problem they helped solve. Even though we might not tell people to go out and buy altezza lights, at least they would be able to see this picture and see the issues this guy had wiring up his altezza lights. Its called "helping people"
Old Mar 18, 2007 | 07:32 AM
Tyte-S's Avatar
Default Re: ebay special taillights (hapexamendios 1)
Ricers? you mean like those kids with big wings, chrome rims and wild flames on their civics? Those kind of ricers?
Old Mar 20, 2007 | 02:30 PM
5G_Vtec's Avatar
My new TYC altezza style tail lights that just came in and hooked them up today.
Old Mar 20, 2007 | 03:28 PM
yellowdcn's Avatar
Default Re: (mustbeballiin)
those altz lights are not honda-tech but to each his own
rumor has it those lights are for mexicans or ur from the east cost
Old Mar 20, 2007 | 03:51 PM
edo_13's Avatar
Default Re: (yellowdcn)
Lol sTEreO tYPing!
I have custom tail lightz and yez im mexican
then again i got it sittin on 18 flatz and black on black with halo headlightzzzzzzzzzzzzzzzzz and airbagzzzzzzzzzzzzz
yez im a bean
o yea dat honda iz just my toy car
i
Old Mar 20, 2007 | 07:43 PM
EXccord's Avatar
Old Mar 20, 2007 | 08:05 PM
Twixle's Avatar
ate my pixel
Default Re: (EXccord)
The lighting on the pic of that CD makes it look almost like a convertible.
