d series
Old Mar 14, 2007 | 05:56 PM
mrEFman's Avatar
Default d series
just wondering what motor comes stock in a 91 ef...and what do i need for a d15b swap....i was kinda thinkin bout going back to stock.
Old Mar 14, 2007 | 06:05 PM
4gcivic69's Avatar
Default Re: d series (mrEFman)
depends on what model you have.. the swap is just a direct bolt in other than wiring vtec and maybe a mpfi swap depending on teh model.. you will also have to swithch to obd1 with a conversion harness
Old Mar 14, 2007 | 06:10 PM
mrEFman's Avatar
Default Re: d series (4gcivic69)
its a base model hatch not a si. so all i will need to do is get the wire harness and wire the vtec. and change from dpfi to mpfi. the d15b will bolt right in other than that.
Old Mar 14, 2007 | 06:24 PM
mrEFman's Avatar
is the d15b vtec the delsol motor?
Old Mar 14, 2007 | 07:20 PM
mrEFman's Avatar
and also what about the hydrolic clutch will that bolt into the ef or whatever.
flipldls
Oct 27, 2009 11:51 PM
importuner_sc
16
Oct 31, 2007 07:14 PM
dougshatch
14
Apr 15, 2007 08:19 AM
99jdem18L
Apr 6, 2006 04:07 PM
URA91hatch
Aug 23, 2004 07:31 PM
